Old 05-04-2003, 05:05 AM
Joe J-Truck Joe J-Truck is offline
Question
I'm musing about a possible Cherokee build-up. I'd like to use the following components: 360, t18, np208, HD D44 front, all from a J20 donor truck. For the rear axle, I was thinking about using a GM 14 bolt rear from a dually truck or a suburban...
My question is: Does anyone know the width of the 14 bolt axle from a 3/4 ton suburban? from a dually pickup? spring perch locactions?
Another option is to narrow both sides of the rear J20 d60 to fit the chero... but this would be $$..
..any other help and/or info would be usefull thanks!!!
-Joe
Old 05-04-2003, 05:50 AM
KYJ10 KYJ10 is offline
I can't help with the dually set up, but I do know that the SRW 14ff is 67" WMS to WMS. I Don' remember if the dually is alittle shorter or longer? Sorry
Starting to miss the addiction!
Old 05-04-2003, 06:02 AM
Stuka's Avatar
Stuka Stuka is offline
There is two versions of the SRW 14FF. The pickup version and the van version. The van version is wider afaik. Then I think there is two dually ones also. Standard and then a extra wide one for bigger van trucks (u-hauls and such) I believe. FSJeeper is the guy to ask, hes the expert on em [img]smile.gif[/img]
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 05-04-2003, 02:35 PM
netbear netbear is offline
For what it's worth, my 1978 rear D60FF from a donor
J-Truck is 67.25" WMS-WMS.
netbear
Old 05-04-2003, 10:53 PM
Sundowner Sundowner is offline
Cab and chassis drw 14 bolts hare 63.25-ish inches wms-wms. they are otherwise identical to the srw truck axles except for the brakes and the wheel hubs.
