Old 03-05-2006, 11:26 AM
RobM's Avatar
RobM RobM is offline
In regards to an 88GW,
Can anybody please id the part next to the red arrow (not the rust)?
I think it is some kind of body mount, it is falling apart but resembles a rubber donut.
thanks
Rob
'88 Grand Wagoneer
Old 03-05-2006, 11:36 AM
Rande's Avatar
Rande Rande is offline
Ph.D in Jeep B.S.
Don't see a thing. Pic posting problem?
N4ZYV
1966 Mustang
1937 IH D2
Old 03-05-2006, 11:37 AM
david13 david13 is offline
no pic or red arrow
74 cj5<br />78 wagoneer<br />86 wagoneer
Old 03-05-2006, 11:55 AM
Rob z's Avatar
Rob z Rob z is offline
I'm not sure but.... it looks like a sign with some words on it.
89 Grand Rottweiler shuttle
Old 03-05-2006, 12:22 PM
PlumCrazy's Avatar
PlumCrazy PlumCrazy is offline
360 AMC
Location: Just S. of Branson (in Beautiful Razorback Country)
Bad, bad Rob...now look ashamed!
Wayne S
Old 03-05-2006, 12:57 PM
RobM's Avatar
sorry - forgot picture
'88 Grand Wagoneer
Old 03-05-2006, 01:00 PM
RobM's Avatar
hope this works
'88 Grand Wagoneer
Old 03-05-2006, 02:58 PM
FSJ Guy FSJ Guy is offline
Yup, it's a body mount. Unless it falls out or you carry heavy loads in the rear, I wouldn't be too concerned about it.
Ethan Brady
www.bigscaryjeep.com
Old 03-05-2006, 03:12 PM
Lazarus's Avatar
Lazarus Lazarus is offline
yep, rear body mount...frame is rusted away from the mount...same on mine and many others...might be a bad thing in a wreck or a side hill but other than that its just a bug...
* A NEW LIFE, A NEW CHALLENGE...EVERY ROCK,HILL, AND BOGGIN HOLE OR BUST... new plans for my rigs, the 74 j truck is getting sold, the 89 wag is a temporary parts rig, and my new to me 85 J10 is getting all the attention... 36" IROKs and a punched out 401 coming its way...
Old 03-20-2007, 07:59 AM
I see what you are talking about now.
Be a PITA but I think you could just weld a new piece in there with the correct size hole in the correct location.
Probably be harder to get the mount off than do the sizing & welding.
Old 03-20-2007, 11:03 AM
Dr Teeth Dr Teeth is offline
If it's like my '71 (and I think it is) you'd have to take the rear bumper completely off (should be able to grind off bolts if needed) and then that rear crossmember of the frame can be unbolted from the frame. On mine there where six bolts on each frame rail (two facing out, two on bottom, two on top). Considering the rust none of them will probably come out freely and all can be easily ground off except the two on the tops of the framerails on each side. Would have to get a nut splitter in there, or maybe a sawzall? Not sure as it's pretty tight with the bodywork in the back. I just trimmed up the body panels in the rear to improve the access, but that's not a fix for everybody.
Todd
Old 03-20-2007, 12:54 PM
yankeedog yankeedog is offline
Yup body mount.eventually the body will start to droop if it hasnt done it already.not the end of the world .my body started to droop when i hit 40. new i guy once who fixed a problem like that with a piece of pressure treated lumber and one or two carriage bolts.it squeaked a little.but it worked.
Replacement body Tallon General FSJ Tech 14 04-29-2006 03:13 PM
Help!! Poly Body Mount Confusion.... hogwagon General FSJ Tech 10 08-22-2004 02:01 PM
Rear Drivers Side body Mount???? Ernzo General FSJ Tech 4 10-13-2003 12:11 AM
Body Squeeaakks...OEM size mounts??? graham General FSJ Tech 10 11-22-2002 04:32 PM
Body Mount Problem on 75 Wag JohnnyJ General FSJ Tech 2 02-19-2001 06:19 AM
