Old 04-23-2021, 08:06 AM
MurderJeep MurderJeep is offline
Manual Clutch Linkage
Hi all, I have a 73 J4000 with a 401 and T18 4 speed. I have never been happy with the clutch linkage, it definitely needs to be more rigid. Does anyone know of any heavy duty aftermarket linkage somebody makes? Or have any ideas on how to improve it?
Thanks!
Old 04-23-2021, 08:18 AM
I have read about some using Hemi Joints to improve it. Pictures and specifics would be great, if anyone has any knowledge on this.
Old 04-23-2021, 09:41 AM
SJTD SJTD is offline
When I converted my '84 It felt kinda mushy. The clutch pedal was hanging off the left of the brake pedal support which I think was the stock arrangement.
I added a bracket between that supported the left end of the pivot shaft from above. Much more better.
Sic friatur crustulum
Old 04-25-2021, 09:31 AM
I have substituted Heim joints on both my J10 and CJ-6. My J20 has a different linkage design and it's not an obvious candidate.
No pictures, but the upgrade is simple in concept. The factory ball-ends on the linkage are of poor quality. They wear out and the linkage breaks. You can lose the short push rod between the bell crank and the throw-out arm. I used the original rod and ground through the spot welds that hold the original ball-end to the rod. I then threaded the factory rod to the thread size of the Heim joint and threaded it on. The CJ was a 3/8" rod and the J10 7/16" IIRC.
Their site is down for maintenance currently, but when it's up, look on McMaster-Carr for suitable Heim joints (rod ends). www.mcmaster.com
Found a picture.
This is the rod from the pedal through the floor to the bellcrank on my J10. You see the worn-out/broken factory ball end. The arrow points to the factory spot weld (crimp?) that holds the ball joint on. Grind through this and the ball end comes off. You can then thread the end of the rod to accept a new Heim joint, seen on a rod above. (the joint above is a CJ-sized 3/8" joint as an example - the J-truck requires a larger 7/16" joint).
Do the same to the adjustable rod that pushes on the clutch throw-out arm. That joint wears out faster, since it's down in the dirt and water under the Jeep. It's on the shorter bell crank arm and sees more pedal force than the long arm.
Old 04-25-2021, 09:56 AM
backroadin''s Avatar
This ^^ is exactly what I did. Works good, and I spray some white lithium grease on them every now and then.
I got lucky, when the link rod fell out from under my jeep, it was in the driveway.
Old 04-25-2021, 10:18 AM
In the meantime, anyone with the factory linkage that has not upgraded their push rods, suggest you use a shoe lace or similar to attach a leash to that rod. If it breaks you won't lose it!
Old 04-25-2021, 11:27 AM
Heep-J4000's Avatar
Back in 03/04 I put also new heim joints on that linkage of the j4000.
Got them at a supplier of farm equipment.
Trucks/car's from the past:
Old 04-25-2021, 07:51 PM
I was not so lucky. In the early 1980 s my J10 dropped the rod when leaving the lake I was fishing. It was winter with nearly a foot of snow on the ground. I gave up looking for it after a short time.
I was able to find two 3/8” drive extensions snapped together to replace the rod. The female end fit on the remaining ball stud and the male end fit into the pocket of the clutch fork. This worked for several weeks before I replaced it.
Spherical rod ends (Heim Joints) are available in stainless steel. I use the 3/8” size on my builds.
There is I believe some difference in the geometry of the bell cranks, this could affect the performance of the system. I think the difference is between the trucks and Cherokee, because the truck body is set farther from the frame than the Cherokee.
Resistance is not futile yet.
Clutch linkage. nw_upstart General FSJ Tech 8 07-17-2010 10:19 PM
Clutch Linkage with 2" BL solved for now :) Gambler68 General FSJ Tech 4 09-19-2008 12:55 PM
clutch linkage yankeedog General FSJ Tech 4 03-22-2007 05:36 AM
clutch linkage yankeedog General FSJ Tech 2 03-15-2007 04:26 PM
Clutch linkage question TexasJ10 General FSJ Tech 17 01-28-2002 12:37 AM
