Old 01-04-2021, 12:47 PM
Harrinad Harrinad is offline
Grand Wagoneer Disaster
I'm trying to put back together a Grand Wagoneer and it's a mess. I'm expecting to post several dumb questions but let's get started here. I'm putting the dash in and there's a canister on the passengers side that looks like it controls something in the heater box. It has a port on it that looks like a vacuum line would connect to it, where does this line come from?
https://flic.kr/p/2kp7FcJ
Old 01-04-2021, 03:37 PM
This one here? The one I have under my dash is slightly different, but I think the other end goes to the hvac controls. My dash is back together now and I can't trace it. I have an 88, what year is yours?
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 01-04-2021, 03:50 PM
SOLSAKS's Avatar
SOLSAKS SOLSAKS is offline
would the TSM show this ?
Old 01-04-2021, 03:55 PM
Mine averages to about an 88. It is a build from an 86 and a 90 but I think that piece was from the 86. I did an engine swap a long time ago and never put it back together. Since then I have forgotten a bunch and some of the original bits aren
Old 01-04-2021, 07:00 PM
Cliff's Avatar
Cliff Cliff is offline
Just take things slow and post questions or issues here. It's a great forum and lots of help is available - real good folks here. It looks like a disaster now but you'll make progress.
Cliff Danley
1977 Cherokee S
Old 01-04-2021, 07:04 PM
letank's Avatar
letank letank is offline
it is the vacuum actuator for the defrost, on the passenger side, the one on the driver's side is the heater...
Good luck with the project
Michel
Old 01-04-2021, 07:14 PM
Originally Posted by letank
it is the vacuum actuator for the defrost, on the passenger side, the one on the drivers side is the heater...
Where can I find the vacuum lines? Do they come straight from the ball on the firewall or from somewhere else? Can I put a T in the vacuum line and connect them to each other?
Old 01-05-2021, 08:56 AM
Vacuum will originate at the Ball on the engine side fire wall and then travel to [supply] the control switch. I believe there is a multi-hose connector that plugs into the controller. You'll need that connector
Old 01-06-2021, 07:44 PM
letank's Avatar
Having a latter model 86 and newer is a tad more involved. The fancy HVAC controller has a special vacuum multiport plug in the rear of the HVAC.
Yes you can plug the vacuum motor to the outlet of the vacuum ball, the vent will activated all the time. Do the same for the driver's side vacuum motor to activate the floor heater vent, connect both vacuum motor to a T and one hose to the vacuum ball is the short and fast way.
Michel
Disaster Strikes see2xu General FSJ Discussion 7 09-27-2015 09:13 AM
QT disaster averted hennikerjd General FSJ Tech 6 01-31-2011 12:13 AM
2 Quarts near disaster 1jeep4me General FSJ Discussion 1 11-12-2010 05:13 PM
Cam gear disaster (Averted) hcm General FSJ Tech 1 01-30-2008 08:40 AM
