Old 12-11-2020, 03:14 PM
Overdrive Transmission Options?
Being a fan of originality and believing you can improve upon that which already exists, I've been looking into ways of improving mileage on my stock drivetrain 88 GW.
Obviously fuel injection is a good way to ensure proper operation, but being that I want to continue using the original 360 engine, I know doing a transmission swap is the best way to lower RPMs and save on gas over our 3-speed 727s.
Problem is, there isn't a lot of info I've seen on fitment and retrofitting of more modern overdrive transmissions in our rigs. I know there's a 360 block used in some 1998 Grand Cherokees and Durangos, so will those 4-speed overdrive transmissions work behind our rigs or are the mounting holes different? Or is that a different block (aka Chrysler vs AMC) altogether?
What other four or even five speed tranny is available, what's "easy", and what else would need done to swap?
Can the NP229 I have be reused? Is there a better xfer case option with an overdrive tranny option?
I'm looking for "as plug and play as possible", wouldn't mind going with a resized drive shaft, but don't really want to swap out much else or have things fabricated.
Any good info out there beyond the search function not really showing me much?
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 12-11-2020, 03:35 PM
Isn't that the Chrysler LA 360? A '98 ZJ could come with a 318, and the Chryco 360 is an upsized version of that. Different. As I recall, some have used the AW4 from an XJ. The WJ Grand Cherokee used the 42RE, a 4-speed overdrive descendant of the 727, with the 4.0L which should be the same bell pattern as your 360. You'd need to work out a flex plate to fit and balance the 360, and the 42RE is electronically controlled - so you'd need some kind of controller. The 42RE in the WJ does not have a stellar reputation for durability, but apparently they can be built to remedy that.
https://www.novak-adapt.com/knowledge/aw4/
Old 12-11-2020, 03:50 PM
I just know there's a spec'd up ZJ that came with a 360 in 98 (and special awesome hood vent extractors, LOL), but figure it's the mopar unit, and not an AMC.
I've read the A518 / 46RH is a 727 with an overdrive gear on it, and doesn't require a controller, but would require a different length shorter drive shaft.
I did see a couple mentions of the AW4, which apparently works well, but requires some adapters, etc.
I can see why many people just completely swap out the engine and transmission both, doesn't seem like many easy tranny options to improve mileage.
--Rob--
My build thread:
Old 12-11-2020, 04:19 PM
J20 project's Avatar
Yur kidding right?..you believe a 70 dodge tranny will bolt onto a 360/5.9 AMc?
Good luck sir.
BP Drivetrain...........
775-537-7918
Old 12-11-2020, 04:36 PM
Good luck sir.
I don't believe anything, hence the word "will" I used in the form of a question.
I know our GWs came with a 727 transmission, which was a Mopar unit, correct? If that tranny worked behind both the AMC And Mopar engines, would a later model Mopar overdrive unit also work behind our 360s?
EDIT: I found this pdf site that specifically mentions the AMC/Jeep 727 not being interchangeable with Mopar engines, so sounds like the later Mopar overdrive units likely won't work on an AMC 360. Too bad, but will do more research.
https://www.novak-adapt.com/knowledg.../automatic/727
"The reader should be aware that the AMC versions of the 727 transmission will not interchange to Mopar engines. The bolt pattern *looks* quite similar, but is not."
--Rob--
My build thread:
Old 12-12-2020, 12:21 AM
crazydog's Avatar
crazydog crazydog is offline
As has been said, the 727 used in FSJ's has a specific case to bolt to the AMC block. As does the TH400 used in the 70's.
Here is how @ristow adapted a Mopar OD transmission to an AMC block.
http://www.ifsja.org/forums/vb/showthread.php?t=51307
If you want an overdrive automatic transmission you can use adapters from Novax to attach a 700R4 to the AMC block and the stock NP transfer case.
https://www.novak-adapt.com/catalog/...r4-to/kit-137/
https://www.novak-adapt.com/catalog/...mc/kit-437amc/
1967 J3500 - Making plans
Old 12-12-2020, 10:06 AM
Ah, very bueno post, thank you!
I'd seen mention of Novak in another thread, but had no idea how much stuff they had available. I'll research them and do a cost analysis. Likely will stay with the ancient 727 and NP229 for a while till they need rebuilding/replacing.
--Rob--
My build thread:
Old 12-12-2020, 10:41 AM
SC/397's Avatar
SC/397 SC/397 is offline
Like mentioned above...
A dodge/cryco 360 is NOT an AMC engine no more than a ford 360 is a AMC engine.
Any transmission that will bolt up to the 4L AMC Jeep engine will bolt up to the AMC V8 engines.
The two automatic overdrive choices for direct bolt up to the AMC V8 and go are the Aisin AW4 or the chrysler 500SE.
I am a believer in the AW4. It is the best automatic transmission I have ever ran.
I have one in my Javelin that works great. Other than these two transmissions, you will have to use an adapter kit.
AW4 Aisin Warner Aluminum 4 oil/water 242 (4.0) 1987–2006 Jeep
500SE (42RE) Chrysler Aluminum 4 oil/water 242 (4.0) 1993–2004 Jeep
The Squeaky Wheel gets replaced in my world
Old 12-12-2020, 06:42 PM
'89_Wagon '89_Wagon is offline
I have a AMC 360/aw4/np229 setup with 3.31 gears and it works well. Also running a GM style TBI. I have not measured the mpg. I did the swap for similar reasons the OP did it for. One thing I don't like about it is the shifter situation. Unlike GM transmission swaps, there's no off the shelf solution so I just used a u-clamp to hold the shifter linkage together. So far, it's fallen apart once. I'm sure there's a better way though. I have a AW4 swap thread on here if you're interested.
With all that said, I'm pretty sure my engine has piston slap so faced with rebuilding the 360 or going LS, I'm going LS with a GM 4 speed.
'89 Grand Wagoneer
AW4 Swap
Old 12-13-2020, 09:06 AM
I would expect any of these swaps would need new driveshafts. If not mentioned, it's because it's so obvious. More speeds implies more guts in the case and a longer case. Plus the car companies have no reason to make different transmissions the same length.
Old 12-13-2020, 01:33 PM
80Limited 80Limited is offline
I have done the AW4 it is worth it.
Old 12-13-2020, 04:47 PM
It's funny I'd never heard of an AW4 before buying my GW, so imagine my surprise when I discovered it's short for Aisin-Warner, both of which I've heard of separately.
I shall research this some more and see if I can figure out how to economically swap at some point.
--Rob--
My build thread:
Old 12-13-2020, 04:50 PM
I have a thread here on the site of what I used.
Old 12-13-2020, 04:52 PM
I think the thread is: AW4 swap complete.
Old 12-15-2020, 08:32 PM
fastjeep fastjeep is offline
Has anybody looked into the 6L80 from GM. Has chevy bell pattern so adapter to AMC engine thru Novak or AA. Novak has adapter to Dana 300 or NP 208 in fsj transfer. There is a controller now to operate the electronic valve body that only needs a rpm and tps signal from any engine so with Fitech injection I have on my J10 will fill those signals. The 6L80 has a 4.02 first gear for great starting torque and 5th and 6th gears are overdrive lowering cruise rpms. The trans are found in 07 to 14 various models as silverados and escalades and corvettes ( are rear mounted to transaxle ) I have one from a caprise police unit that was crashed. Will need to go to a floor shifter as column will not have the required detents. You can also use paddle shifters if you want to. The over all length is only about 2 inches longer than 727 trans.
Old 12-16-2020, 09:35 AM
Love the idea of a 6-speed to really improve the MPGs (I read in Car and Driver awhile back each gear improves things 8-12% over the next lowest gear), but it sounds overly complicated with the extra sensors and inability to mate to the column shifter. I'll think about that and see what we have locally in the yards.
--Rob--
My build thread:
Old 12-16-2020, 07:04 PM
Here's a link to my AW4 swap. I completed this over the summer and I think I had $1k into it. Definitely could be done for less. Little stuff adds up quick and I pieced it together. First transmission I put in was junk...$200 down the drain. Junkyard charged $400 for a low mileage one... 120k miles. Be picky about the year.. the electronics change and I would say 95/96 is the sweet spot.
Also, mounting the 4WD vacuum motor for the NP229 was challenging. Because a spacer is used between the NP229 and AW4, the bracket just doesn't work without modification. Also, there are hard vacuum lines that mount against the transmission and I did not find an easy way to secure them. Easy enough to replace them with soft lines but I didn't. I saw somewhere recently that rocklaurence makes a twin stick shifter. I would have gone with that even though it may lose some of that stock appearance. In fact... I may buy one soon!
http://www.ifsja.org/forums/vb/showthread.php?t=187654
FWIW, I think the 6l80 uses the same type of shifter lever on the transmission as the 4L80/4L60 so there should be some off the shelf solutions to hook that up to the column shifter. Also, there are no detents in our column shifter.... the positions felt come from the transmission manual valve body (lever thingy on the side of the transmission). Fortunately, the AW4 linkage does line up well with the stock 727 linkage.
One thing to be aware of, there's not much aftermarket support for the AW4 like replacement parts. Obviously tons for GM transmissions... and they're newer.
'89 Grand Wagoneer
AW4 Swap
Old 05-06-2021, 08:41 AM
PlumCrazyChris PlumCrazyChris is offline
[quote=SC/397]Like mentioned above...
SC/397,
So your saying that these two trans will bolt up to an AMC 360/401? I thought that during those years, the engines were mopar?
I've installed a A518 (46RH) into my 70 Challenger with an 08 Hemi, so I'm familiar with making those operate, but didn't know there were AMC options of the A518/A500. And if its bolts to a 258/4.0, then it will bolt to a 360? Is that correct?
Have you done this swap successfully? If so, do you have a writeup you can provide a link too?
Thanks so much for the info!
PlumCrazyChris
Round Rock, TX
1990 Grand Wagoneer - sold
1983 Cherokee Laredo Limited - sold, and want it back!
1979 Cherokee Chief - sold
1976 Cherokee Chief - sold
Old 05-06-2021, 11:30 AM
Originally Posted by PlumCrazyChris
SC/397,
The 5.2L and 5.7L (318 and 360) V8s that were available in the ZJ Grand Cherokee are Chrysler engines. The 4.6L V8 used in the WJ Grand Cherokee is a Chrysler engine.
Both of the applications referred to above (ZJ, WJ) were offered with the 4.0L HO six cylinder engine. The WJ got the 42RE with the 4.0L, not sure about the ZJ - probably the same. The 4.0L engine has the same bell pattern as the gen-3 AMC V8s (304, 360, 401) as well as the '71 or later 232 and 258 inline 6s. Presumably anything that bolts up to the 4.0L will bolt up to the AMC V8s, if you can sort out the starter and flex plate issues. I don't know about that.
Old 05-06-2021, 11:32 AM
I'd copy this:
transmission and t-case options bshoke General FSJ Tech 1 05-25-2011 06:06 PM
Modern Transmission Options for the 230 Tornado I6 The PIG Smith General FSJ Discussion 10 04-28-2011 10:19 PM
Vigilante 327 transmission options?? dirtman General FSJ Tech 13 01-04-2011 12:43 AM
Overdrive options? AKAMC General FSJ Tech 21 11-17-2008 02:54 PM
transmission options for '63 to '67 bigblack'74 General FSJ Tech 2 12-07-2004 10:25 AM
