  #301
Old 04-29-2021, 10:00 PM
FleetFox's Avatar
FleetFox FleetFox is offline
Glad your OK. Love the old ford, we have 3 of the same vintage. These models will be running after the apocalypse...
Fleet Fox
Old 04-30-2021, 01:51 PM
Wagoneer Taylor's Avatar
Wagoneer Taylor Wagoneer Taylor is offline
Fleet Fox
That Tractor is a Beaut! It has required nothing more then regular maintenance over the years.
Some call me Taylor...
Pewter, Blue Interior, Original 401
PO swapped in a 360, soon to be a 401 again!
"Soon" is a relative term.
Cracked cylinder put a hurt on me + bad connecting rods.
Old 04-30-2021, 11:51 PM
I guess wrenching on Ramcharger 2.0 is good to help pass time waiting on your engine. That dude should hook you up for taking so long.
Old 05-03-2021, 03:04 PM
It definitely does, and I hope so as well.
Old 06-16-2021, 07:52 AM
So how are the the Taylor-mobiles doing these days?
Old 06-16-2021, 07:30 PM
Hey Rang!
Thanks for asking, things are going well actually.
I literally got the call today that the engine is ready to be picked up from the machine shop!!
And the Ramcharger 2.0 should be ready to drive this weekend.
Making really good progress on the Ramcharger but nothing new on the Wagoneer since I hadnt got the engine back.
Update on the Wagoneer coming late this week or early next
Ramcharger update, engine is in, and running (I will try to post the video of the first start with open headers ) and it got new wheels and tires as well as a lift. Lift and tires below.
[IMG]
[IMG]
Old 06-16-2021, 07:52 PM
Let me know if the above post works??
Old 06-18-2021, 11:41 PM
SJTD SJTD is offline
I see you about to spray the magic stuff into the carb.
Sic friatur crustulum
Old 06-19-2021, 02:21 AM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
Holy crap, I’m glad you are ok. Also glad you got another ram charger. they’re not Jeep’s, but still really awesome for sure. Had a accident kinda like this in a forerunner, had new tires but a aluminum rim came apart in a corner. Hit a ditch bank and did a front flip back into the road. Very thankful for Toyota engineers. On the Passenger side the roof was touching the top of the seat. Walked away with a few scratches on my hand, and a huge adrenaline dump. Hope you get everything swapped soon.
-2000 Volkswagen Jetta diesel
-1976 Wagoneer 401/Turbo 400/QT with 4 low/Dana 44s
Old 06-21-2021, 01:08 PM
Thanks jeepjseries, glad you made it out of the crash as well.
Not sure I can get the video to work.
Old 06-29-2021, 09:23 AM
Its finally happening ladies and gentlemen!
I brought home the 401 from the machine shop 6/25/2021, exactly a year and 1 day from when I dropped it off.
I got the block on the engine stand, and unloaded all the parts. I bought a master rebuild kit from the machine shop (surprisingly it was cheaper through them then I could get it all for).
Got my doctors table all set up with the tools I knew I would need to start on this, along with the bible and torque wrench, plus a notebook.
Old 06-29-2021, 09:26 AM
I then immediately found a problem in step #1.
Install the crank bearings, the thrust bearing does not have the tang that holds it from spinning, on either half, both halves have a hole in them instead of just 1, and they do not match the old set that I had.
Will be calling the machine shop this week to try and get it resolved quickly
Old 06-29-2021, 10:49 PM
Is the tang supposed to be in both?
Maybe you got two tops?
What book are you following?
Old 06-30-2021, 07:27 AM
My old set has tangs in both top and bottom, and a oil passage only in the top.
It is possible I got two tops, and really only one needs the tang I guess.
Its either the Chilton or Haynes manual I cant remember. Not actually saying these are the best for these rigs but its what I have.
Old 06-30-2021, 05:26 PM
I suspected from what I could see of it.
Look on oljeep.com. You can prolly find the jen-u-wine Jeep book.
Old 07-01-2021, 10:30 PM
I do not think the thrust bearing has the tang. Standing by to see what the machine shop says. Maybe pm sc/397 and ask him, too.
Old 07-02-2021, 08:04 AM
Thanks SJTD! I forgot I saved that link some time ago with those manuals!
Old 07-02-2021, 08:08 AM
Machine shop said it should have the tang, Rang. Sorry couldn't resist the rhyme there. I went and talked with the guy from the machine shop, he had a set in stock that was 0.02 over and the thrust bearings had tangs, unfortunately I need 0.01 over
Also old set had the tangs on both halves. I would be concerned if at least one half didn't have the tang, what would keep it from spinning?
1977 Jeep Wagoneer Galvanized Metal ??? ngasman General FSJ Discussion 3 05-18-2015 03:07 PM
1971 Jeep Wagoneer 1414C with Factory 1972 Engine ngasman General FSJ Discussion 10 11-28-2014 11:27 AM
I need a wedding jeep Fayetteville,Ga kowboy84 General FSJ Discussion 3 05-11-2014 08:07 AM
Picking up my 2nd Wagoneer, a 1978 with a 401! sallad General FSJ Discussion 6 12-15-2013 08:46 PM
