Old 08-24-2013, 06:46 PM
88sunroof 88sunroof is offline
Removing Studs from Sway Bar Dog Bones to Replace Bushings
I am replacing all of the bushings in the sway bar system, but I can't seem to separate the "dog bones" (which attach to the front axle) from the sway bar itself. Are these joining bolts/studs/whatever pressed into the sway bar? Threaded in? What is the best way to remove them so that I can replace the bushing which surrounds them?
1988 Jeep GW
Need to replace rear shackle bushings? adzam General FSJ Tech 0 08-24-2012 01:53 PM
Removing Pully to replace fan bolts? 80wag General FSJ Tech 7 12-05-2011 08:03 PM
removing wheel studs Crossbones General FSJ Tech 13 11-01-2007 09:35 AM
It's time to replace my body bushings Mountainvice General FSJ Tech 3 03-11-2005 07:36 AM
Poly sway-bar bushings: REAL easy and cheap upgrade! (with pictures and part #'s) Bob Barry General FSJ Tech 8 07-27-2004 12:56 AM
