Old 11-03-2010, 02:03 AM
mjragona mjragona is offline
long tube headers
hey yall ok so i have an 88 grand waggy v8 i can find long tube headers anywhere to save my life and iam trying really hard couse i like to put an full exhausts on my jeep so if any body know good headers to go with spin tec mufflers i would be really greatfull or just long tube headers that will go with the jeep one more question if yall can help can i use the headers off the 5.9 dodge engine let me know thanks again everybody
Old 11-03-2010, 03:10 AM
Skeeter74 Skeeter74 is offline
As far as the Dodge motor, no. The AMC 360 and the Dodge 360 are totally different animals.
You could very easily find a set of shorty headers, then do what you will with the rest of the system.
Originally Posted by Tatsadasayago
"And on the 7th day god created the Full Sized Jeep and he saw that it was good. He gave these mechanical marvels to his chosen ones and they went wheeling in style and comfort!"
80 Wagoneer Limited, 2 bbl 2150, 360, 727TF, NP219, "Moby Dick" Now with Dragonfire HEI, Contour dual fans, CS144,
Old 11-03-2010, 09:37 AM
Josh D's Avatar
Josh D Josh D is offline
Can't help with your long tube header question, but I can help with making your post more understandable. Try using punctuation.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 11-03-2010, 09:40 AM
dlowrance's Avatar
dlowrance dlowrance is offline
I don't believe you're going to find any long tube headers that'll fit your rig. Shorties are going to be your only option AFAIK...pretty sure after the 80 diff change there's not enough room for long tubes.
Dale
80 W/T Cherokee - "Liz"....4bt??
69 J3000 DRA Dump - King Triton!!
It's the little things: Light Bulbs KensAMC General FSJ Tech 21 11-02-2019 01:40 PM
J truck long steering tube badscooter General FSJ Tech 1 09-04-2008 02:42 PM
Square Tube Driveshafts rustywagoneers_com Off-Road FSJ Tech 21 03-11-2006 09:25 AM
My Plans and Lots of Questions (kinda long) Tigger General FSJ Tech 7 09-09-2003 06:19 AM
Info for new FSJ owners (long post) jode General FSJ Tech 16 02-07-2003 02:43 AM
