Old 11-16-2021, 11:22 AM
gl21133's Avatar
gl21133 gl21133 is offline
88 GW 5.9 Engine Block Heater Leak
Per the title I've got a coolant leak, appears to be entirely coming from the engine block heater. It has a hex fitting in the center, I was able to tighten this maybe 1/8 turn but it's still got a few drops this morning. I take it this is just pressed into the freeze plug hole, right? Remove, clean, replace?
Old 11-16-2021, 08:49 PM
gl21133's Avatar
Possibly dumb question; for a short while would it be dumb to deal with rtv? Just on the outside until I can properly swap it.
Old 11-17-2021, 07:57 AM
Tripwire's Avatar
Tripwire Tripwire is offline
id just buy a new one?
steve
Abort? Retry? Ignore? >
Old 11-18-2021, 08:53 AM
'89_Wagon '89_Wagon is offline
5.9's came with an engine block heater? Is that aftermarket? Would love to see a picture.
'89 Grand Wagoneer
AW4 Swap
Old 11-18-2021, 09:10 AM
dealer installed or aftermarket none came with one from factory afaik
Old 11-19-2021, 02:26 PM
letank's Avatar
letank letank is offline
here is a pict, not mine,
http://www.ifsja.org/forums/vb/showthread.php?t=162622
I have a similar one on the 85, and yes it was dripping 20 years ago... I was told to smack it with a punch and it would dislodge... nahhhh, did not happened...
I poured some coolant leak repair powder... and yes, the coolant temp was a bit higher, I drove it for about a month, then drained a bit of coolant, may be a few quarts... temp was still a bit high and drained another few quarts... and the leak never came back...
Of course in 20 years I replaced the water pump, drained the coolant a few times... still leak free
Michel
freeze plug style engine block heater w/ pics cjarcher General FSJ Discussion 11 01-04-2013 09:57 AM
Engine coolant leak - additive? haynesm General FSJ Discussion 20 04-19-2011 10:19 AM
Question about flushing engine block JFlu General FSJ Tech 15 08-04-2009 09:57 AM
Electric Engine Heater? AnnieL General FSJ Tech 11 06-15-2009 09:18 PM
Block Heater Install???? 88GW General FSJ Tech 5 10-01-2003 02:01 PM
