Difference between '65 - '69 PS box and '70 - 73?
  • J20DAN
    • May 12, 2002
    • 168
    Can anyone tell me the difference between the PS boxes between the earlier '65-'69 Saginaws and the later '70 - 73, maybe later, parts book only goes to /73. Very different part #s. Will the later fit the earlier?
    1979 J20, Firecraker Red
  • Cliff
    • Mar 30, 2002
    • 864
    Priot to 1972 AMC was using the Eaton PS pump. Did Jeep always use the Saginaw?
    Cliff Danley
    1977 Cherokee S
    • J20DAN
      • May 12, 2002
      • 168
      Thanks
      • Cliff
        • Mar 30, 2002
        • 864
        Wait - I wasn't even thinking of the Buick 350 which would have used the Saginaw. But while the pumps may be same or similar obviously the brackets wouldn't be.
        Cliff Danley
        1977 Cherokee S
        • tgreese
          • May 29, 2003
          • 11682
          I presume the OP means the steering gear, not the steering pump. Jeep calls this a "steering gear assembly." Pretty sure "steering box" is a colloquial term. I expect you could use either the Eaton or Saginaw pump for a Saginaw gear.
          For power steering gears, the parts book just gives a part number, not much else. Since it was used through '69, I would also presume that it's a Saginaw type and not the 230-era Ross unit. I believe you can tell something about the unit from the numbers cast in to the housing, if someone on here has a representative unit they can look at.
          • drcom
            • Oct 02, 2011
            • 259
            I have a 1970 Wagoneer with the Buick 350. Is there anything I can do to help? My steering box has the adjustment on the top that I see with the Saginaw boxes. I am guessing that makes it a Saginaw ? If there is a part number, I can take a scrub brush and go looking or take pictures. My wagon was made 9/1969 and therefor is considered a 1970 model with the custom designation. Power steering and power brakes.
            1970 Wagoneer Custom (9/1969)
            Original Arizona Jeep
            Buick 350/TH400/Dana20
            Early model with razor grill
            Spring Green exterior (original)
            Custom series interior
            • J20DAN
              • May 12, 2002
              • 168
              Dr. Com if you can take a photo of your brake pedal assembly that would be helpful, so I can see what the difference is between 1970 and 1973.
              Thanks
              • drcom
                • Oct 02, 2011
                • 259
                Sorry, I was down for a while but I am back. I will take a picture tomorrow and post. Do you want the brake pedal or power steering ? I am getting ready to put in the adapter on my brake pedal to move the brake switch from the bottom of the master cylinder to the inside brake pedal.
                • J20DAN
                  • May 12, 2002
                  • 168
                  Actually if you could take photos of both that would be great.
                  thanks
                  • Herk
                    • Jun 12, 2006
                    • 1123
                    As far as I know they all use the same basic Saginaw 800 series steering box. The position on the frame changed in 72 to allow for the larger slanted AMC radiator. The boxes themselves are standard GM parts https://leepowersteering.com/pages/h...entify-gearbox
                    FWIW I swapped to a Camaro Z-28 box for quicker ratio and firmer response.
