Old 11-28-2021, 07:00 PM
Cliff's Avatar
Cliff Cliff is offline
Tired of Slamming Doors
I installed new BJ's door jamb gaskets on my 77 Cherokee three years ago. I expected them to be tight for a little while but three years later I still have trouble closing my doors. Alignment is good although I have made several adjustments in an effort to fix the problem but the rubber just seems to be too thick. I have tried sunlight, protectant, hot air, etc. I even rebuilt the hinges on one side to see if there was any improvement but no success. The door metal is not making contact on the jamb anywhere. Sill plates are flush and tight.
Any ideas?
Cliff Danley
1977 Cherokee S
Old 11-28-2021, 07:40 PM
Remove some material from the rubber.
Some people drill small holes where it won't be seen, others use soldering irons, etc. Either way, sounds like you need to remove some rubber somewhere to decrease the amount of push back against the door.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 11-29-2021, 10:02 AM
I've read, here I think, that there was a change at some point in the thickness of the seals and BJ's seals fit the later models. Edit: Or maybe it was the location of the mating or mounting surfaces?
Maybe you can search up the thread.
This is a topic I keep my eye on since I'll be needing the seals soon. You'd think I'd save those threads for that reason.
Old 11-30-2021, 10:10 AM
jon.westfall jon.westfall is offline
I put a BJ's door seal on one door of my 71 Wagoneer and found it pretty tight. For $50 dollars I purchased some similar door seal from Amazon, only it is 1/2" bulb instead of 5/8" and it is still a little tight but better, but I did the other three door for a lot cheaper. You can order a 15' length for $20 and experiment. Corners don't look as clean though. On mine the tight spot was on the door right where the latch and handle are because the door flares out just little.
Old 12-01-2021, 08:15 PM
Crankyolman's Avatar
I put them on my '72 and when I got tired of slamming the doors I took them off and slowly installed them while closing the door and found that when it got to somewhere around even with the latch plate it required the slamming to close. My solution was to take a crescent wrench and gently bend about 4 inches of the flange away from the door until the seal made the correct amount of contact and now it closes fine.
'72 J4500
Old 12-03-2021, 01:33 PM
Cliff's Avatar
Crank - your idea worked! I looked at drilling and removing rubber but your suggestion seemed simpler. Thanks for all of the replies!
Cliff Danley
1977 Cherokee S
Old 12-04-2021, 08:28 PM
Mikel's Avatar
Mikel Mikel is offline
Hi - Got a part number on the Amazon seal? Thanks.
1969 M715 6x6
1963 J300 Swivel frame
Old 12-06-2021, 10:38 AM
I used this one:
https://www.amazon.com/gp/product/B0...0?ie=UTF8&th=1
Bending the pinch weld near the latch as mentioned earlier helps a lot as well.
Old 12-10-2021, 08:49 PM
Glad I could help
'72 J4500
Old 12-11-2021, 08:17 AM
Adjusting the pinch flange that the seal is attached to is standard procedure at the factory where the Jeep was built. However a hammer and a wood or plastic block are used instead of an adjustable wrench. By the way any brand of adjustable wrench will work as good as the Crescent brand. I am particularly fond of Utica brand adjustable wrenches. The fit on the moving parts seem superior to all others.
I have a similar opinion about Allen brand of hex key wrenches. So many consider them the go to hex key wrench but I have found the Unbrako hex keys as good or better than Allen
By the way, has anyone noticed the advertisement at the top of this page recently? This was promoting a sight where one could find price value for used Jeeps, associated with the add was a picture of a Land Rover.
Resistance is not futile yet.
Old 12-11-2021, 10:16 AM
How come I get the feeling you have a thing about using Manufacturer's names as generic?
Old 12-11-2021, 05:26 PM
I believe the "Crescent" wrench I used was actually manufactured by Diamond Tool and Horseshoe company but I have a number of them manufactured by various companies only one of which is Crescent. I also have a number of "Ford" wrenches only one of which has the name Ford on it. I also have one of these
Railroad wrench sometimes called a Monkey wrench.
I'm sure any one of these "adjustable" wrenches could have done the job
'72 J4500
Old 12-14-2021, 04:28 AM
When one collects things he begins to develop a passion for them. If you ask me for a Channellock when in my shop I may hand over a hammer. (Yes, I have hammers made by Channellock)
Old 12-14-2021, 11:07 AM
I know what you mean. People referring to polyurethane as "polly" and aluminum as "alloy" annoy me.
Then there's people calling gun stocks "furniture". Even in gun magazines where they should know better.
Old 12-14-2021, 05:06 PM
'scribing. I have the same seals, and same slamming issues...
Old 12-16-2021, 02:10 AM
Mikel's Avatar
I used this one:
Thanks!
1969 M715 6x6
Old 12-22-2021, 10:19 PM
inkedmonkey inkedmonkey is offline
I just gave this a shot with my BJs seal. It worked great. Just had to bend the door flange back to allow the thicker seal to fit. No more slamming!
Old 12-27-2021, 02:24 PM
Originally Posted by threepiece
... By the way any brand of adjustable wrench will work as good as the Crescent brand. I am particularly fond of Utica brand adjustable wrenches. ...
100% True Story:
In the late 90's when I was in the Navy, I asked one of my junior techs to go grab me a "crescent wrench". He came back with a set of Crescent Brand hex wrenches. I am not the type of person that would go off a newbie so I sat there for a second staring blankly at the wrench set and said "oh, um... could you grab me an allen wrench?" and he came back with an Allen brand adjustable wrench.
I was dumbfounded that:
a) our tool kit actually had a Crescent brand allen wrench set AND an Allen brand Crescent wrench.
b) my tech made it through about 21 years of life including 14 years of education in New Jersey, bootcamp, and about 2 years of Navy training on electronics, Radars, missile and gun control systems yet he did not know "Crescent wrench" generally means "adjustable wrench" and "allen wrench" generally means hex wrenches.
I couldn't even be a little annoyed since he grabbed me EXACTLY what I asked but we had a 15 second training period and laughed about it together.
Old 12-27-2021, 04:21 PM
100% True Story:
I've gone through that sort of thing with a Korean and other people who didn't grow up speaking English. The Korean has no idea what a crescent wrench is, to him it's a "monkey wrench", even though to me a "monkey wrench" is the one pictured above.
and one time I was directing a group of 6 people during a delicate operation and discovered that the Iraqi born person didn't stop when I told him to "hold up" because he didn't know what it meant.
'72 J4500
Old 12-27-2021, 11:20 PM
I'd have said he was messing with you like threepiece proposed but I guess not.
Front Cherokee doors and center cap question Carol1982 General FSJ Tech 23 02-11-2015 10:36 AM
better way to mount/hang doors TheChief General FSJ Tech 5 04-07-2011 06:25 AM
Tube Doors, Half Doors, No Doors... What About Weather? krek General FSJ Tech 6 08-27-2008 03:07 PM
2 doors/4 doors are the doors the same?? chopperimpala General FSJ Discussion 2 03-01-2008 10:19 PM
Question for all you guys without doors... 72wag Off-Road FSJ Tech 11 05-27-2004 05:59 PM
