Old 05-29-2022, 12:50 PM
SJTD SJTD is offline
Vanity Light
Can someone tell me how the vanity light wires get through the headliner? About to install the new one.
Sic friatur crustulum
Old 05-30-2022, 08:43 AM
backroadin''s Avatar
Just a hole in the liner under the light. Wires run up inside the drivers door post and along (behind?) the roof brace. That's on a 73, though.
Old 05-30-2022, 11:37 AM
Thanks but I'm referring to the light on the passenger visor. I dug out my sun visor and the wire has a kink in it. Looks like the connector stays inside the headliner and you tuck it in as you mount the visor, the kink happens at the edge of the cup/trim/whatever.
Old 05-30-2022, 10:09 PM
Doh! Vanity... shoulda caught that.
Old 05-30-2022, 10:25 PM
After doing some more searching I'm thinking the wire goes through the cup under the visor mounting flange rather than under the outer flange. The cup has a slot from the center hole to the edge of the bottom of the cup.
Old 06-01-2022, 09:44 AM
Brynjminjones's Avatar
I believe (from memory) that what you've described is correct.
Be careful not to pinch the wire - I did that once and it took me ages to figure out why the dome fuse kept blowing!
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360, .030" over with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
How to: Fixing final edition flip-lid light up visors adzam General FSJ Tech 3 11-25-2012 10:29 AM
third brake light? Eric S. General FSJ Discussion 9 12-23-2011 04:16 PM
Charge light wire connection ? 1cdccop General FSJ Tech 0 12-26-2010 06:44 PM
Courtesy light and dome light TestTeam General FSJ Tech 10 06-01-2007 11:20 PM
Dome Light country boy General FSJ Tech 9 09-20-2002 09:04 PM
