Old 12-07-2021, 05:48 PM
mwood65's Avatar
mwood65 mwood65 is offline
Oil Pressure?
I was wondering what the general consensus is on what oil pressure is in the safe limits?
Got the gauges in my 74' Cherokee (258 engine) and at idle it is 20psi and going down the road at around 2500-3000 rpm it has 40 psi.
I thought that was ok but what do you guys think?
Need for concern?
Old 12-07-2021, 06:37 PM
Tripwire's Avatar
Tripwire Tripwire is offline
mine aint that good.....probably 10 PSI at idle if im lucky and 20-30 on the highway....have a tired engine, IIRC the least you should have is like 10 PSI for every 1K RPM ????
Abort? Retry? Ignore? >
Old 12-07-2021, 09:25 PM
backroadin''s Avatar
These jeep sixes were known for low oil pressure. Having 20 at warm idle is pretty good. They might not have had that when new!!
Many a 258 is still tickin' tho, even with lousy oil pressure.
4.0's weren't a whole lot better either.
Old 12-07-2021, 10:37 PM
mwood65's Avatar
Thanks guys,
You said what I was already feeling but wanted to make sure.
Old 12-08-2021, 05:35 AM
Brynjminjones's Avatar
Hey, that's the same (if not better than) I get from the newer 4.0 I6 in my '98 XJ Cherokee!
1991 Grand Wagoneer - Hunter Green. All stock. Rebuilt 360, .030" over with Melling MTA-1 cam.
1998 Cherokee (XJ) 4.0
1997 Grand Cherokee (ZJ) 4.0
1974 Ford F100 390
Old 12-08-2021, 08:22 AM
Old Ironsides's Avatar
Old Ironsides Old Ironsides is offline
Super Low
On Ironsides, it is only 2-10PSI at idle, and 20-25 on highway, depending on how hot it is At some point, I'll do the pump mod. Its been this way for at least 10K miles.
Grant
Old Ironsides: '76 J-10, 401 (1406/2131/DUI/RV Cam), TH400, Part Time, 3" lift, 33s, 346K Miles
Ironsides: '75 J-10, 360 (1406/2131/MSD), TH400 QT, 6" lift, 33s, 110K Miles
'77 Cherokee Chief, 401/Th400, QT, 4" lift... Totalled
'79 Wagoneer, 360, TH400, QT
Old 12-08-2021, 10:26 AM
I'd say 20 at hot idle and 40 on the highway is good, really good. The old rule-of-thumb is a minimum of 10 psi for every 1000 RPM. This puts you well within the safe operation envelope. You should not be winding out a 258 anyway - the stroke is very long which makes torque peak at low RPM, and puts a lot of force on the rod bearings at high speed.
Air Conditioning an 87 Grand Wagoneer mantonas General FSJ Tech 38 04-28-2022 07:06 PM
Need a little help Crankyolman Fuel Injection 71 11-04-2020 10:46 AM
WHERE did my oil pressure go (long) bockslanding General FSJ Tech 6 03-05-2009 05:37 AM
727 UPGRADES J10-401 General FSJ Tech 18 02-13-2007 08:21 AM
no oil pressure - long post, please be patient jhanson General FSJ Tech 3 08-07-2004 06:16 AM
