Old 06-10-2021, 04:34 PM
Tripwire's Avatar
Tripwire Tripwire is online now
constant tension clamps - edited
I changed all my caddy's coolant hoses recently, i reused the clamps- have had 2 leaks, one a minor seepage - but today the Damn upper heater hose on the firewall popped off on my wife whilst shopping. had to rescue her , it was a easy fix , but i want reliability not convienence...
What do you guys / gals think?
Steve
Abort? Retry? Ignore? >
Old 06-10-2021, 05:11 PM
inkedmonkey inkedmonkey is offline
I like the old wire clamps with the bolt and square nut. I try to use them everywhere I can, but unfortunately I still have some worm clamps in use.
goldhammer's Avatar
Generally replace the clamps with new when I do a hose change. The couple of bucks difference is worth the peace of mind
Art
ASE Master Collision Tech
Old 06-10-2021, 05:17 PM
If you want quality worm drive clamps, Westlake Hardware has stainless ones. They are better than the cheap ones from the parts store.
Old 06-10-2021, 05:22 PM
Tripwire's Avatar
i have not seen the wire ones with the square nut in ages....they are still made?
Old 06-10-2021, 05:30 PM
Tripwire's Avatar
well lookie at amazon....they are indeed still around, wonder if they come in stainless.....What was the reason everyone shifted from them? did they cut hoses?
Old 06-12-2021, 01:52 PM
Tripwire's Avatar
more spring clamp questions
I have a question about the "constant tension" hose clamps in todays cars - I am old fart used to worm gear clamps.
1. the clamps must come in different "clamping force" right? you would not need the same clamping pressure for a radiator hose as you would a vapor hose....? or less pressure on a plastic nipple VS more on a metal one?
2. If so, how do you tell which clamp you need for a given hose?, is there a secret chart somewhere? the reason I ask is i replaced all my radiator hoses and re-use the old clamps - if i wanted to buy new ones how can i be sure i'm ordering the correct ones ?
Steve
Old 06-13-2021, 10:40 AM
SJTD SJTD is offline
I guess you're not an old enough fart. I remember the spring clamps from our '64 Valiant. Never worked on our older cars, a Hudson and a '49 Merc convertible he gave to the kids across the street where it got thrashed. Where's the weeping Smily? But I bet they had spring clamps.
Anyway, I think the screw clams became popular in the aftermarket because they're easy to work with and seem to fit a big range of sizes with a single clamp. Though they really don't fit properly unless the screw part has the correct curve. Spring clamps are self adjusting withe temp changes and can't be overtightened.
Does any car come from the factory with screw clamps? None of my unmolested cars have screw clamps except the Dodge on the intake hoses.
Sic friatur crustulum
Old 06-13-2021, 02:38 PM
AM Woody AM Woody is offline
Worm clamps here. I never bought that the spring type self-adjusted for temperature or hose shrinkage or whatever. I always thought the factories used them only to speed things up on the assembly line. Probably cheaper too.
- Andy M.
89 Grand Wagoneer: White/Cordovan. Factory tow package. Gradually undoing PO's mods - it seemed like a nice build at the time.
Status: Operational
Old 07-02-2021, 07:53 AM
KayBur KayBur is offline
Steve
Do you have the right repair tools? Maybe it's easier to go to a car repair shop? Sometimes it is cheaper and faster to pay for repairs to the masters, it seems to me.
Old 07-02-2021, 09:34 AM
Steve
just like regular worm drive clamps they have a size range
usually in mm. measure the hose and use a clamp in that range.
i prefer the newer clamps they don't tear up hoses and don't deform/bend like worm drive clamps.
the proper tool is mandatory
i actually replaced all the worm drive crap on my caprice with decades old spring clamps from boneyard whenni replaced all the hoses.
Old 07-02-2021, 04:35 PM
jeepjseries's Avatar
jeepjseries jeepjseries is offline
I think the main reason they use tension clamps is cost and ease of removal and install. If you have the tool for them, it’s quite handy. You can remove and install them in seconds. That being said. They are like anything else, quality of the clamps makes a huge difference.
Another thing is hoses expand and contract over time, the tension clamps are really good for this. They work really well for silicon hoses as well. I like and use both, just depends on your preference really. Of course if it’s higher pressure probably not the best choice.
-2000 Volkswagen Jetta diesel
-1976 Wagoneer 401/Turbo 400/QT with 4 low/Dana 44s
Old 07-02-2021, 10:04 PM
Best $30 I've ever spent was on cable operated locking hose clamp pliers.
Old 07-03-2021, 10:05 AM
constant tension are far better. on smaller hoses like on the average car the benefits aren't as obvious. on bigger equipment like otr trucks it's common to find coolant under the truck the first cold snap of the year due to loose worm clamps.
Hose clamps Bkgw FSJ-PRIS 2 07-19-2016 03:01 AM
Coolant Hose Clamps Texafornian General FSJ Tech 7 03-12-2015 12:15 PM
Whacky Ramsey worm drive idea fsj1978 Off-Road FSJ Tech 0 03-13-2008 10:41 PM
Excellent Site For Hardware and Almost Everything Else! Wag the Dog General FSJ Tech 2 06-01-2004 02:57 PM
hose clamps on springs gc4x4 General FSJ Tech 5 11-11-2001 03:38 AM
