Old 03-30-2008, 02:42 PM
Chumley360 Chumley360 is offline
Input bearing retainer question
I need to lengthen the throwout bearing slide on my input bearing retainer. This seems to be a cast peice so I'm not sure if it can be done or not. Does anyone know if this is do-able?
1968 M715-Driveway queen/in progress
Old 03-31-2008, 05:31 PM
tardyboy's Avatar
tardyboy tardyboy is offline
You mean like this? This one was extended by welding a iron sleeve of similar size then milled smooth. I had this done by a local machine shop and was charged 80.00 for it . I have never run it so I don't know how strong it is, also this is for a t98 and I have a t18 so I'm not even sure if it will even work for my application.
Old 03-31-2008, 06:44 PM
I've also seen a sleeve made, and the retainer turned down to accept the sleeve. The sleeve would extend further than the original retainer, and was held on by a collar and set screw at the back end.
Old 04-01-2008, 02:34 AM
Tardyboy that's exactly what I am looking to do. I need to add about an inch to the end of the one I've got. Cool
Thanks guys.
Old 04-01-2008, 04:28 PM
tardyboy's Avatar
Glad I can help.
Old 04-02-2008, 12:52 AM
oldyellowwagoneer oldyellowwagoneer is offline
Are you missing the original one, or did you swap in a longer input? Call six states and ask them what they can get. Dennis
“Don't do anything by half. If you love someone, love them with all your soul. When you go to work, work your *** off. When you hate someone, hate them until it hurts.” Henry Rollins
