Old 08-10-2007, 06:06 PM
tylerd13 tylerd13 is offline
how many quarts of atf
How many quarts to fill up a turbo 400 tranny, I snagged 5 from my work, and some lucas tranny fix, think that should be enough?(well I'll find out soon) also I got every other fluid imagenable so I can get the cherokee all finished up this weekend, Should have some wheeling pics up by next weekend if everything goes alright.
77 Cherokee 360/sm465/205, 1 tons, 38's
84 4runner on 35's
Old 08-10-2007, 06:12 PM
10fenny's Avatar
10fenny 10fenny is offline
fill from dry, or what. i think its about 12 if the t-converter is drained. i would prolly stay away from that lucas oil thickiner crap, unless you got some real problems your tryin to cover up
Old 08-10-2007, 07:03 PM
really? alright well I just figured it couldn't hurt and i got it for free. so its not that big of a deal
84 4runner on 35's
Old 08-10-2007, 07:09 PM
10fenny's Avatar
ya, dont use it unless u really really dnt have money for a rebuild. its prolly not gonna help the bands grab anybetter, prolly just keep it from leakin.
Old 08-10-2007, 07:16 PM
it says it also helps it from overheating. and the tranny shifted good last time I drove it.
84 4runner on 35's
Old 08-10-2007, 07:24 PM
10fenny's Avatar
well with the thickend oil theres gonna be less friction and heat. what condition is the tranny, if is about to go thats one thing. but if you have it completly dry u must done somethin, t-converter? theres no reason to use it, your just gonna make drag with thick oil, and yes, ,there gonna claim a lot
Old 08-10-2007, 07:27 PM
all I did was swap trannys, I think the torque converters still full, I didn't take the converter off when I removed the tranny.
84 4runner on 35's
Old 08-10-2007, 07:37 PM
10fenny's Avatar
k, then its prolly only in need of about 9 qts i wanna say
Old 08-10-2007, 07:40 PM
janie's Avatar
janie janie is offline
Dexron Impaired
The TH400 holds about 11 quarts of ATF. Since your not sure if the tc is still full or not, the easiest way to do this is to just fire up the rig and bring it up to normal operating temp's.
Add a couple of quarts and then shift thru all the gears, including reverse. Leave it running the whole while, and just keep checking your dipstick until you reach the full mark.
Whatever you do, DON"T overfill or the top of your dipstick tube will look like a rabid dog.
