Old 02-02-2010, 07:13 AM
duncanstives's Avatar
duncanstives duncanstives is offline
Your 2do list
So... Whats on your 2do list for your Jeep?
Just curious if everyone's list is as long as mine... Share your 2do lists and plans for your rigs here...
Mine:
http://spreadsheets.google.com/ccc?key=0AuL2Np3tEZZUdDM3dWdsZ3pNbG13Nk8zZmxKM0prV 3c&hl=en
Kind of seems like it never will be done . Then again everything shows up as "not started" because I just made a new list... The old one got cluttered up with too many "completed" things
88 Waggy
Resting in peace... Um... In piece... Er... IN PIECES
Current Status: Under construction. Phase 2.
86 Pathfinder Conversions "K-Van"
Current Status: Broke
Volkswagen rail buggy
Current status: Broke
95 Jeep ZJ V8
Current status: DDing
Old 02-02-2010, 08:12 AM
Not a bad idea unless you have several FSJs.
They tend to set the agenda, not me.
Old 02-02-2010, 08:31 AM
Dumpy's Avatar
Dumpy Dumpy is offline
2 New Tires (Anyone have any donor or cheap33x12.50x15's close to me? Or just one 33x12.50x15 BFG MTR (I have one as my spare, and would swap out one of my worn ones)
Replace 1/2 ton rear springs to 3/4 ton (sitting in basement)
2-3" Lift
Fab front bumper
Full Exhaust
Better Stereo
New fuel gauge and sending unit
New temp gauge and sending unit
E-Brake set-up
Brake booster
T18 conversion
Can't let the wife see this. Just spring it on her one thing at a time
Justin
'72 J2000 360 4bbl T18 D20
Old 02-02-2010, 08:50 AM
Josh D's Avatar
Josh D Josh D is offline
To keep it simple and in perspective:
1. mechanical
2. interior
3. body/appearance
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 02-02-2010, 08:57 AM
710 Burner's Avatar
Not all FSJ, but I have 7 sets of wheels on the ground here, and I know exactly what you are talking about.
and yes, the Jeep list is long enough. Its kinda in flux inside my head right now, and I am balancing what should be done against what needs to be done right now. I can get the Big Dog out from under the snow now, and just got a timing belt put on the baby diesel, so that heater core has got to go!
Mark B. Jones
Old 02-02-2010, 09:31 AM
if I try keeping all this stuff in my head I will forget most of it... Lol
88 Waggy
95 Jeep ZJ V8
Old 02-02-2010, 11:18 AM
WagonWheel's Avatar
WagonWheel WagonWheel is offline
Currently working on 1-7 and few others, but non are complete just yet.
JEEP PROJECT LIST AND IDEAS
1. ALTENATOR
2. BATTERY
3. FREEZE PLUGS
4. INTAKE MANIFOLD
5. HEAD GASKET
6. FUEL GAUGE
7. FLOORPANS
8. WINCH
9. FRONT BUMPER / CUSTOM DASH
10. ROLLCAGE
11. FRONT LOCKER
12. FRONT SEATS
13. MOVE SHOCK MOUNTS TO TOP OF AXLE IN REAR
14. DIFF COVERS AND PROTECTORS
15. 205 DOUBLER
16. BLUETOOTH CB AND ANTENA
17. STEREO SYSTEM
18. 4 LINK
19. KC LIGHTS
20. CHOP TOP BEHIND REAR SEAT
21 HUB UPGRADE
22.REMOVE TAILGATE AND WELD IN SOLID SHEETMETAL REAR AND INSTALL AFTERMARKET STOP/TAIL/TURN AND REVERSE LIGHTS.
23. NEW TIRES / SUPERSWAMPER IROK 42/15/16.5
24. U-JOINT UPGRADE
25. HYDRAULIC ASSIST STEERING ( ROCKARM-AGR (BRAND) )
26. HEADLINER
27. ON BOARD AIR
28. PROPANE
29. BRAKE UPGRADE
30. ROCK SLIDERS
31. REAR SPARE TIRE CARRIER
32. REAR BUMPER / BODY MOUNT SUPPORT
33. SHOCK UPGRADE
34. RIHNO LINE FLOOR FRONT TO BACK TOP AND BOTTOM
35. UPGRADE HAVAC
36. GPS
37. AUDIO VIDEO
38. BUILT IN COOLER
39. HARNESS STYLE SEATBELTS FRONT AND BACK
40. BEAD LOCKS
Old 02-02-2010, 11:31 AM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
I have to do the following:
-bushings
-brake job
-shocks
-springs
-grease bearings
-re-lube diGreat Googley MoogleyGreat Googley MoogleyGreat Googley Moogley
-clean engine bay
-rewire gauge cluster
-fix heater blower
-fix window motors
-install flexracs
-install tailgate window assy.
-door panels
-int. carpet
-seats
-cargo panels
-speakers
-rewire int. lights
-rewire ext. markers
-front fenders
-grill
-tires
-bumper
Whew!
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 02-02-2010, 11:35 AM
srobertsfsj's Avatar
srobertsfsj srobertsfsj is offline
My list was alot longer a few months ago.
  • Replace old gas
  • Swap in NP208
  • Identify exhaust leak
  • Fix exhaust leak
  • Rebuild carb
  • Replace power steering pump
  • Check diff fluids
  • Check TC fluids
  • Check steering for wear
This doesn't include all the little upgrades I want to do but lack of $ keeps them off the list.
Scott R.
'86 Grand Wagoneer Super Chief 360 / TBI / WT conversion / 35x12.5x16 BFG Mud-Terrains (Project Link)
Old 02-02-2010, 11:36 AM
x6xdemonx6x's Avatar
x6xdemonx6x x6xdemonx6x is offline
after flopping it i got more to add to my todo list
alternator-after extensive testing it would appear mine is good so-done
weld up the shackle mount area where the weld popped-done
hang new bumper
pull doors that got smashed gut em and put them into the new donor doors
TFI Upgrade-done
Mini spool
Swap in new rear lift springs in in place of old flat springs and lift blocks
New tank skid plate
New vaccum lines and reroute them
figure out why my electric door locks aren't working
Figure out why my keys don't unlock my doors either
I think thats it for now.
FREE 91 grand wagoneer 360 2barrel 4" lift 31" tires rebuilt tranny and tcase dana 44 front and rear
TFI upgrade
Old 02-02-2010, 01:20 PM
1. ALTENATOR
2. BATTERY
3. FREEZE PLUGS
4. INTAKE MANIFOLD
5. HEAD GASKET
6. FUEL GAUGE
7. FLOORPANS
8. WINCH
10. ROLLCAGE
11. FRONT LOCKER
12. FRONT SEATS
15. 205 DOUBLER
17. STEREO SYSTEM
18. 4 LINK
19. KC LIGHTS
21 HUB UPGRADE
24. U-JOINT UPGRADE
26. HEADLINER
27. ON BOARD AIR
28. PROPANE
29. BRAKE UPGRADE
30. ROCK SLIDERS
33. SHOCK UPGRADE
35. UPGRADE HAVAC
36. GPS
37. AUDIO VIDEO
38. BUILT IN COOLER
40. BEAD LOCKS
Wow... Long list of major projects!
I remembered a few more to add to my list this afternoon.
88 Waggy
95 Jeep ZJ V8
Old 02-02-2010, 02:03 PM
billyj7175's Avatar
I have a 5 year plan...
1. Tow/haul my J10 from storage in Oklahoma...
2. Motor/tranny overhaul...w/cs-144, de-smog, clean/paint/tidy up the engine bay...
3. Interior...seats, stereo, carpet, sound-deadening...
4. Rhino grill?...(maybe)...
5. Paint...
6. Maybe a re-gear...maybe...
83 J-10 Jeep "Oscar"
360/727/229
Old 02-02-2010, 02:14 PM
dlowrance's Avatar
dlowrance dlowrance is offline
On the cherk that list is fairly short...
1 - remove
2 - repair/replace
3 - install
4 - repeat
start at the front and work my way back!
Dale
79 WT Cherokee
401
TH400
D20 Twin Stick
Unnamed as of yet....
Old 02-02-2010, 02:41 PM
Chris P.'s Avatar
Chris P. Chris P. is offline
1. I need to make some new clutch linkage out of heim joints but keep putting it off.
2. The ECM needs a little more tuning for cold starts and open loop.
3. Rust free bed and paint.
79 J10 Honcho 360/T-18/D20
Summit 8600 cam, GM TBI
78 Wagoneer 360/TH400/QT
Old 02-02-2010, 02:45 PM
rockin wagoneer's Avatar
rockin wagoneer rockin wagoneer is offline
things to do for my waggy
1.one pull my 327 vigilante
2.pull old axles and put new ones in
3.put soa and lift kit in and bracket drop in the back
4.put new gas take and full pump in
5.new paint job
6.redo my 327 and put it in
7.put new rims and tires on
8.new battery
9.new exhaust
10.new dash
11.new bumpers front/rear
i know im forgetting alot of stuff but owell u get the just
love it,live it,be it JEEP!!!!
79 cherokee- dd on 36s
78 wagoneer-rebuilding
Old 02-02-2010, 02:47 PM
JAWs7227's Avatar
JAWs7227 JAWs7227 is offline
1. Get the J10 garaged
2. remove hood and bed
3. compile massive list of parts
4. tear down, save the chassis, clip, complete cab, fenders, interior, axles, and complete drivetrain
5. find a solid rust free bed, tailgate, and hood
6. prep and primer the body
7. build a complete rolling chassis
8. new carpet, headliner, tilt column, white leather buckets
9. rebuild engine w/ headers, hotter cam, edelbrock intake, maybe heads, new carb and aircleaner
10. rebuild tranny and T-case w/ Mile marker kit
11. axle rebuild?
12. paint
13. reassemble
14. sit in my garage and stare at it because i'll be too afraid to drive it after all this work and money spent.
Jess
1976 J10, 360 2v, TH400, Q/T, 131"
1979 CJ-5, 258 2v, 3-spd - Sold
1992 XJ Laredo 2-Dr, 4.0L, Auto - Sold
1992 YJ Islander, 4.0L, Auto - Sold
1998 TJ Sahara, 4.0L, Auto - DD
Old 02-02-2010, 03:22 PM
addicted's Avatar
addicted addicted is offline
Big Meanie
Here's my list and some of it i've already done but ran into other issues that require re-doing it.
1.reconnect and recharge my A/C
2.plumb the evap system
3.wire up the fuel pump/sending unit
4.weed out unneeded wires in the engine harness and splice in the GW wires
5.regear the front axle (waiting until I know the rear is right)
6.adjust the Lokar column shifter to the trans
7.recover the headliner and overhead console
8.install the fron parking brake cable and adjust
9.clean up and mount the inside spare tire carrier
10.put the door panels back on
11.make up t-case shifter linkage
12.replace the front brake hoses (one side left to go)
13.bleed the brakes
14.inspect and repack the front hubs/bearings
15.properly torque all the spring bolts and nuts
16.rebuild my newly acquired NP208
17.get a spacer made to adapt newly acquired 208 to the AW4
18.get drive shafts made up (again)
and there are other misc. things that will come up as the list gets finished
Originally posted by Ristow
i bet it was Simon....
Old 02-02-2010, 04:07 PM
draglink's Avatar
draglink draglink is offline
1. Working on a rebuild on a 360 to drop in this spring
2. Swap 229 for 208 at same time
'86 GW 6" Rustys, 1 1/2" BJs shackles, 33 BFGs
Old 02-02-2010, 08:00 PM
Dirt Wag's Avatar
Dirt Wag Dirt Wag is offline
wider wheels
wider and bigger diameter mud tires
replace 6" lift springs with stock springs
spring over in front
shackle flip kit in back
trim fenders for bigger tires
steering box brace
rear axle brace
differential guards
wheel the hell out of it
1985 GW, 360, 727, NP229, D44, AMC20, HEI, SOA/shackle flip 7" lift, Quick Lok locker rear, Aussie Locker front, 4.10 gears, 37 X 13.5 Interco SS-M16's, Warn Premium hubs, Tuff Stuff 12,000 LB winch, rear disc brakes === stripped down street legal off road toy
Old 02-02-2010, 08:22 PM
vintagetrks's Avatar
My List.
1) Go to store get lottery ticket.
2) Win Lottery
3) Cash Lottery Check
4) Pay someone to fix my jeeps LOL
New Full Size Jeep Nut
90 Grand Wagoneer "Big Mama"
