Old 10-13-2021, 07:21 PM
VandalRon VandalRon is offline
Carb for 401 ci
I took my 78 Wagoneer into THE Boise Carb shop to have it rebuilt. The tech said that the factory carb on that engine was the worst carb ever built. He would rebuild it but.... I should think about another carb.
Are there Holley, Edelbrock or Summit (or other) carbs that will bolt to the factory manifold?
Old 10-14-2021, 01:44 PM
Bc409 Bc409 is offline
I also have a 1978 with a 401. I agree with your carb guy! I rebuilt my 4350 and it still was awful. Got the Summit 600 cfm vac secondary elec choke. I do have to also get an adaptor. The 1978 spread bore pattern is a freak. Not like a quadrajet. I really like the new carb.definitely recommend.
Old 10-14-2021, 01:47 PM
To be clear, I am running the summit carb and it works great
Old 10-14-2021, 07:11 PM
Great info and thank you. All you needed was an adapter? Did you get that from Summit as well?
Old 10-14-2021, 07:21 PM
Part numbers
Would it be possible to get that part numbers if possible?
Old 10-15-2021, 05:17 AM
The MC 4350 is a great carb until it isn't. They tend to warp with age. Experience varies.
TransDapt 2199 will adapt a square bore 4bbl to the Ford & Jeep spread bore pattern intake.
https://www.summitracing.com/parts/trd-2199
Old 10-15-2021, 08:32 AM
Carb question
I'm retired but work P/T at an auto parts store and get a great discount. Can you recommend a Holley or Edelbrock carb? I'm not opposed to buying the Summit (as long as I get the correct one) but if the Summit carb is based on a Holley or Edelbrock and I can save a dollar, why not? I'm looking for a "fuel economy" carb, LOL, for this beast of a Jeep.
BTW, Thanks for all your help. I'm delighted with the responses.
Old 10-15-2021, 12:55 PM
Carb
Summit m2008 series. SUM-MO8600VS
Old 10-15-2021, 01:18 PM
Thanks
Will I need a throttle linkage kit with that?
Old 10-16-2021, 10:52 AM
I did not need a linkage kit. Just the adaptor. It was a straightforward bolt on.Modify fuel line with piece of rubber line and fire that baby up
Whistle coming from carb or intake -Resolved. jsmorris General FSJ Tech 11 10-08-2015 06:12 PM
258 with Offy intake and Holley carb questions KensAMC General FSJ Tech 5 10-01-2010 05:22 PM
Won't start after relocating Ignition Coil and Carb Cleaner Tahnka General FSJ Tech 7 08-17-2005 08:23 AM
New carb and intake how-to. bluesman2a General FSJ Tech 6 12-19-2004 04:30 AM
Rebuilt carb ----> Gas leak! (UPDATE) jode General FSJ Tech 15 11-25-2002 05:10 PM
