Old 03-20-2011, 07:28 PM
kill-billy's Avatar
kill-billy kill-billy is offline
leaf spring bolt size?
as the title states, im wondering what size bolts are in my leaf springs? ive tried the search feature on here and came up with nothing.
i found one post on another site and they said 9/16 x 4.5 so i thought i would check with the FSJ gurus here to be sure as the closest likely place for me to get them is an hour away so i dont want to make two trips.
im planning to install my lift kit next weekend so i just want to be sure i got some replacements as im sure some wont come out easy...lol
its an 87 grand wagoneer.
i appologize if its a rediculous newbie question.
Thank you.
Old 03-20-2011, 07:42 PM
loganvilledude's Avatar
loganvilledude loganvilledude is offline
I just took a quick measurement. .575 on a dial indicator fine thread bolts with nylon nuts, but the length is 8" from bottom to top. I'm running 4" Skyjackers. Hope this helps!
89 Wagoneer / White Woody / 4" Skyjacker / 360 AMC / A Former Odessan
http://s244.photobucket.com/albums/gg8/odessadude/
Old 03-21-2011, 05:11 AM
kill-billy's Avatar
the bolts are 8" long? did u measure your u-bolts or the bolts that go through the leaf spring eyes?
its the bolts that go through the eyes that i am asking about.
Old 03-21-2011, 09:31 AM
HellCreek HellCreek is offline
Almost all of the center bolts used in FSJ rear springs are 3/8" with a 9/16" fillister head. A quick substitute would be a 3/8" socket head cap screw. They have the same size head and are easier to install, due to the allen wrench socket in the head. FSJ front springs use a 3/8" bolt with a 1/2" fillister head. You could also use a socket head cap screw, but you would have to either grind down the head diameter or enlarge the hole in the axle saddle (perch) to accommodate a 9/16" bolt head.
Thanks,
Tom
Old 03-21-2011, 10:17 AM
kill-billy's Avatar
thanks for the posts folks. however i dont think i worded my question properly. or maybe im misunderstanding... can u tell im new to fsj's? lol
im looking for the measurement of the bolts that go through the eyes and shackles.
Old 03-21-2011, 10:34 AM
I have a couple here I just peaked at, looks like 4 3/8" long so I'm sure 4 1/2" will work.
More Leaf Spring /AAL Install Questions Seemer General FSJ Discussion 7 12-07-2010 08:14 PM
Ring gear bolt tourque j20brett Off-Road FSJ Tech 24 03-10-2009 09:43 AM
R44044 Leaf Spring Info jepj2000 Off-Road FSJ Tech 30 04-14-2008 08:55 AM
Just in case... bolt size needed... Dirtball Off-Road FSJ Tech 2 09-12-2007 07:45 PM
leaf spring u bolt sizes tommynguyen02 General FSJ Tech 0 05-10-2007 09:11 PM
