Old 09-01-2021, 08:19 PM
Tripwire's Avatar
Tripwire Tripwire is offline
Two hydrogen atoms walk into a bar.
One says, I think I’ve lost an electron.
The other says, Are you sure?
The first replies, Yes, I’m positive…
Steve
Abort? Retry? Ignore? >
Old 09-08-2021, 02:04 PM
Originally Posted by SJTD
Can you still by the two part flush? Was in a stacked can with oxalic acid in one and a neutralizer in the other. The acid component reduced the rust meaning converted it back to iron. This causes it to shrink and loosen up.
I read once that a molecule of rust is 10x the size of the iron molecule it started as so it shrinks a lot. I should look that up and verify now that info like that is so easy to find.
Oxalic acid is still available for bleaching wood, I think, even if not as a cooling system cleaner.
Hydrochloric acid, aka muriatic acid scares me as a flush agent.
You can put together the equivalent of the old 2-part kit. GM published a service bulletin on flushing coolant systems that you can find online if you search. You need wood bleach (oxalic acid) and washing soda (sodium carbonate). Both chemicals can be purchased OTC. I expect the 2-part kits were banned because of indiscriminate dumping of the waste water.
Oxalic acid combines with rust to form iron oxalate - basically turning the rust into an organic salt that dissolves in water. It's a mild acid that has to be safer for your water pump bearings and seals than muriatic acid - likely more effective too. There may be similar materials available today that are more environmentally friendly. The washing soda is a benign neutralizer.
Old 09-12-2021, 09:05 PM
stonehengeheels's Avatar
stonehengeheels stonehengeheels is offline
Can you post a picture of that T connection please? Thanks.
Originally Posted by letank
I used the prestone for neglected cooling system and followed direction... I installed a flushing T by the heater hose to back flush the cooling system with a garden hose... and it took about 20 gallons to have a clear liquid out of the radiator, the iron blocks have a lot of rust.
I have been using distilled water for the last 10 years ... but in the early years I used dionized water from our lab still.
Interesting post from Tripwire about not using DI water...
Steve
'87 GW (Totaled)
'90 GW (Under renovation)
'00 GC Laredo (Totaled)
'02 GC Laredo (Sold)
'67 Dodge Coronet Convertible 440/727/3.55
Old 09-12-2021, 10:58 PM
letank's Avatar
letank letank is offline
here we go, various sizes to fit any hoses... I installed it on the hose between the heater core and the intake manifold, prestone flush and fill kit:
and the radiator top detail (different fsj)
https://cdn.shopify.com/s/files/1/22...g?v=1578615048
As for the drain/outflow on top of the radiator, the yellow fitting barely fit after a few uses, so you need to hold it with some support to keep it in the same level as the radiator cap fitting
Flush cooling befor new rad & htr core? davidpsalt General FSJ Discussion 0 10-24-2012 05:36 AM
Cooling system wierdness Tripwire General FSJ Tech 6 10-31-2005 03:44 AM
Best Cooling System uglyjeepling General FSJ Tech 42 06-13-2005 11:55 AM
probably not the last word on cooling.... brent General FSJ Tech 38 07-18-2003 08:29 AM
"an exhaust system can also be too efficient." Jerk General FSJ Tech 25 09-12-2002 03:58 PM
