Old 06-10-2021, 10:51 AM
waggygrady waggygrady is offline
AC help
Hi all. I have a 89 Grand and have the AC components on the inside but nothing under the hood. (V8)
Can any one post a diagram of parts needed under the hood and layout. Only have the compressor mounting bracket in place previous owner removed everything else.
Thanks
Old 06-10-2021, 11:25 AM
oljeep.com
has parts manuals and service manuals with pics
Old 06-13-2021, 06:47 PM
mrtazwrench's Avatar
mrtazwrench mrtazwrench is offline
I have misc. A/C parts, I installed it on my J20 which never had A/C, I still have parts from other vehicles. You can buy the condenser, dryer, and expansion valve new, and maybe the compressor. You might have to find a shop to make the hoses.
Chad
"Let's see that Red Blue Green **** sucker build one of these without duct taping it together!"
https://www.facebook.com/media/set/?...3&l=76427b95fd
88Wag
87J20 Member, FSJ Prissy Restoration Association
83Cherokee WT
82J20
Parts vehicles: 1.5 Wags, 3.5 J20's, 1 J10 1 J300
Old 06-21-2021, 08:18 PM
I think wagonmaster sells an AC hose kit now. Price seems reasonable too. Wish I knew about that before I did my system and bought the crimping tool, fittings ECT.
'89 Grand Wagoneer
AW4 Swap
Old 06-22-2021, 07:31 AM
There isn't much to it. There's a couple of hoses from the compressor, one goes into the cabin to the evaporator, and the other goes to the condenser mounted near the radiator. Also two 1-wire connectors for power (orange?) and bypass (black?), I think.
Do you also not have the hardline with the sight-glass on the passenger inner fender, or condenser mounted near the radiator?
Which mount do you have? Since it's an 89 I assume it's for the ovoid Sanden unit, not the rectangular York unit.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 06-22-2021, 02:28 PM
I have heard it said, on here and other places:
Originally Posted by lots of folks
You are going to spend a lot more money trying to get a factory Jeep/AMC A/C system to work (buying parts, finding pieces, poor fitment, etc) than if you just buy a kit
I have no experience to help so take this with a grain of salt. Mine does not work and I plan to fix it in the next 12 months so I read a lot of posts on A/C here and it is a common thought amongst some folks.
Old 06-22-2021, 09:16 PM
FleetFox's Avatar
FleetFox FleetFox is offline
Check out my build thread and accompanying Flickr album. It may be useful to some extent. I did "remodel" the factory air, but updated to a Sanden compressor and made the system 134a compatible. I had new hoses made using the metal parts of the originals. The rest of the front parts were new repops of the originals bought of the net. Deleted the sight glass and moved the low pressure switch from the fender to the drier. SonaraEd on the other forum helped me a lot with it.
Fleet Fox
AC evaporator freezing up Brynjminjones General FSJ Tech 8 08-31-2017 02:06 AM
AC Converted to R134A and now HISSING RVAWagon General FSJ Tech 18 07-07-2016 12:50 PM
Cooling question in Wagon with 360 with AC dkmcgowan General FSJ Tech 30 09-10-2014 11:43 AM
AC Controls Subconscious General FSJ Tech 4 08-03-2005 02:34 PM
