Old 10-11-2004, 12:26 PM
Folks,
I have a 1983 Cherokee Laredo with the Dana 44 (Front axle disconnect via vaccum) and a NP-229 Transfer case, just so you know.
I took a trip this past weekend and ended up pulling the front driveshaft due to a rear U-joint failure (no genius mechanic here, eh?).
So I left the U-joints installed and unbolted and removed, but neglected to mark anything.
Is it going to vibrate on me when I replace both U-Joints on the front drive shaft?
What are the best choices in U-Joints (I have a 4-Inch Superlift), I have heard that the non greasable units were tops, but just don't know....
I have 1350's on the rear driveshaft to the Dana 60, so which one's should I put up front?
Old 10-11-2004, 12:58 PM
Gawdzilla.'s Avatar
Gawdzilla. Gawdzilla. is offline
worse case Joe, you can try turning them 1/4 turn if they do vibrate and reattaching until you get it right. I didn't mark mine first time around either...guess I got lucky [img]smile.gif[/img]
I could be wrong, but I think the joints are all the same part #. At least I'm pretty sure they are on my 74. What's the parts site say?
Ed Mitchell
74 J10
Old 10-11-2004, 01:03 PM
I am afraid to ask the monkeys behind the parts counter...
You know the routine..."Yep those big Jeeps are "Sweeeeeeet", you have the Chrysler 318 or the 360...."
Guess I'll dig out my TSM and check it?
Old 10-11-2004, 01:37 PM
Thanks!
Old 10-11-2004, 01:57 PM
Gawdzilla.'s Avatar
welcome!
Ed Mitchell
74 J10
