Old 06-16-2018, 02:05 PM
fadec's Avatar
fadec fadec is offline
Question Steering column length?
I decided it will be easier to just replace the steering column in my '68 J3500 due to lack of parts availability. I'm still deciding which of the big three makers to go with. Either Flaming River, Ididit, or Speeway.
So as to know what to shop for, I need to know the length of the steering column installed in a '64-'71 J series truck with a column shift automatic. Anyone done a column swap with an after market GM style column and knows how long it is?
I know I can simply measure it once it is removed, but I would like to research this and order parts BEFORE removing my old column. Thus I'll have still have a truck I can move, while I await parts. Space is very limited and I can't have the truck blocking the driveway without a steering column while parts on order.
1968 J3500 - Buick 430, TH400, D20, D44/D53, Townside
1981 CJ7 - rock crawler w/ custom tri-link suspension & coil springs, 383 stroker L98 TPI
2010 JK - all the normal bolt on stuff you can think of. 4" Currie lift, 37" tires, stubby bumpers, flat fenders and such...
Automatic Steering column/ Manual steering column compatibility posulli88 General FSJ Tech 2 02-04-2018 12:27 PM
Replace lower steering column bearing w/o removing column? posulli88 General FSJ Tech 2 02-03-2018 06:41 AM
Fuel Gauge / Steering Column Question Golden Eagle General FSJ Tech 2 03-22-2011 05:24 PM
Steering Column Compatibility Jacksons Hole General FSJ Tech 0 03-13-2011 10:16 AM
