Old 09-17-2015, 06:43 AM
Road Hammer's Avatar
Road Hammer Road Hammer is offline
Noob!
AMC 360 Heads with Comp Cams Magnum Rockers
Hi Everyone,
Well my machinist has hit a snag on my 360 build. We were attempting to use Comp Cams, Magnum rockers (pt # 1442-16), without guide plates but there is too much movement of the rocker side to side. We are going to try the Comp Cams, Magnum, rail type rockers (pt # 1431-16), because they do not require guide plates.
Has anyone done this? Will they work?
The heads are '74, 360 doglegs with bridged rockers. Casting # 322 0502.
Thanks for your comments...
MarkB...
Bold Springs, GA.
1983 Cherokee Laredo
Old 09-17-2015, 09:16 AM
SC/397's Avatar
SC/397 SC/397 is offline
I prefer the Scorpion SCP-1097
http://www.flatlanderracing.com/scorpionrockers.html
Old 09-17-2015, 01:21 PM
You are either gonna need guide plates or self guiding rockers if you want to stay with stud rockers.
Why not just put guide plates in?
That your machinist couldn't tell just by looking at the heads that guide plates would be needed is not a real confidence booster on his end.
Old 09-18-2015, 10:35 AM
acct21's Avatar
acct21 acct21 is offline
+1 on the Scorpion rockers. Used a set in the 400 Ford we built a few years back, and couldn't have been happier with them.
Old 10-08-2015, 02:19 PM
Noob!
Hi Everyone,
I wanted to close out this thread. As it turned out, the Comp Magnum "railed" rockers did not work with the 360 heads. The rail on the rocker contacted the valve retainer rather than the valve tip. My machinist thought he could grind the rails, but we found a better solution.
Performance American Style sells a pushrod guide plate kit that fit my 360 heads without having to modify the plates. We had already milled the stud bosses for rocker studs and these guide plates allowed us to use the original Comp Magnum rockers that I had originally purchased. The guideplates are $64.95 a set and saved the day for my build.
http://www.performanceamstyle.com/Ca...00a85&divi=amc
It has been suggested that Scorpion rockers are a bolt on solution and if I done my homework, I would have gone that route. Live and learn!
MarkB...
Bold Springs, GA.
280~300hp on stock low comp 84' 360? jeepin87 Street & Performance 12 09-01-2015 12:00 AM
Roller Rockers on 360 david gibson General FSJ Tech 2 06-14-2012 11:48 AM
Heads and rockers JeepNOFEAR General FSJ Tech 2 03-02-2006 01:58 PM
304 heads on a 360 fsjwagoneer General FSJ Tech 10 04-02-2003 03:07 AM
AMC 360 heads chrisnsarah General FSJ Tech 9 05-06-2002 04:05 PM
