Old 04-08-2012, 10:52 PM
wag4x6's Avatar
wag4x6 wag4x6 is offline
Whats the stickiest situation youve got your FSJ into?
Heres mine(so far...)
89 Grand Waggy, freshened up 360, 727, NP229, SOA/SF, highsteer w/ chevy knuckles, Dana 44's f/r, 35" Maxxis Big Horns, some rock rash and more to come....
R.I.P 87 Waggy
www.socalultimate4x4.com
Old 04-09-2012, 03:06 AM
PlasticBoob's Avatar
All Makes Combined
None...and that's why I still have it, while other members have come, chopped, cut, banged, scraped, crunched, rolled, and then left over the years.
The frame did split up by the steering box once when I was off-roading, but luckily I was able to have it welded back up. That's when I realized I should start treating her better.
Rob
Click for video
Old 04-09-2012, 05:39 AM
svining's Avatar
svining svining is offline
Boob,
Reminds me of a poster I saw once in the Pilot's briefing room,
"The best pilot knows not to get himself into a position, to where he must demonstrate his superior flying skills!"
Tonight's exercise "Nap of the Earth (treetop) insertion flight with Night vision goggles"
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 04-09-2012, 08:38 AM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
Wag 4X6 has that iconic image as well?
I do too!
This was the only time I had the feeling of rolling.
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 04-09-2012, 09:34 AM
j20brett's Avatar
j20brett j20brett is offline
360 AMC
Only major breakage ive had to date. Wedged a rock between the bumper and tire. Started winching forward giving it some gas so it would pop up and the only pop i heard was the front driveshaft grenading. Ended up winching forward and backwards simultaneously to get off the rock (backwards).
Build Thread
Fight Crime...Shoot Back.
ΜΟΛΩΝ ΛΑΒΕ
Old 04-09-2012, 10:01 AM
CommanderChaos's Avatar
CommanderChaos CommanderChaos is offline
The water went from 6" to 3 feet. It took two vehicles to pull me out.
My flex fan ate my radiator when I hit the water/mud. I won't use a flex fan again.
1988 Grand Wagoneer, 360/727/229, 6" Rusty's Lift, 35x12.5.15 Goodyear wrangler MT/R w/ kevlar. 4.56 Gears, Yukon Chrome Moly Front Axle Shafts, Eaton E-Locker Front and Rear, ARB Differential Covers.
Old 04-09-2012, 12:21 PM
Herk's Avatar
Herk Herk is offline
Afternoon traffic in Minneapolis.
Old 04-09-2012, 12:31 PM
orangecherokee's Avatar
you are awarded no points
Old 04-09-2012, 01:23 PM
FSJ-Earl's Avatar
FSJ-Earl FSJ-Earl is offline
The "Frog Hole" at Rausch Creek, I had water over the headlights, up to my seats in the interior. Took two baby jeeps with winches to pull me out. Cost me a tranny rebuild, power seat motors, power window motors, power door lock motors, stereo amp, interior carpet, and anout 3 weeks worth of work.....
Also was in a bad situation in Harlan, KY several years ago in a dry streambed. 3 guys standing on my rear bumper to keep my rig on three tires.
Great times!
FSJ-Earl
Old 04-09-2012, 08:24 PM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
See the tire mark on the rock off the driver's side? I made that on the way down this "trail." Before I got this far back up though, I got high-centered and broke an axle-shaft, u-joint, and spring; all at the same time. There's water on both sides and it's about 100' deep! Having my son with me, it was a very behind-puckered-day.
Here's the "high mark" on the way down:
Hope the pics aren't too large. Here's the album from the day. For whatever reason, I lost the pics of the ratchet strap holding the front passenger spring in place for the 30 mile, hour and a half long drive home.
http://s267.photobucket.com/albums/i...-09/?start=all
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly Occasional driving!
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1977 J10 4v401, TH400, BW1339, mostly stock DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 04-09-2012, 08:28 PM
KJ Ryu's Avatar
Looking at those pics, I know now that I never should have been there! The J10 is almost ready to go to places like that now, though.
Ron
Old 04-10-2012, 12:30 PM
Amc71601's Avatar
Amc71601 Amc71601 is offline
Mine got stuck near a lake in some nasty mud, the mud went about halfway up the tailgate. Then because of the angle I was at & almost being out of fuel it died & wouldn't restart . To make it worse a guy in a toyota on 38's showed up & proceeded to drive around mine to make it really fun to get out, then he couldn't pull me out. Luckily I know a guy with a wrecker & a lot of cable.
Low voltage situation solved dbuie General FSJ Tech 6 12-19-2009 01:38 PM
Overheating Situation '88 J20 Double V General FSJ Tech 9 07-07-2009 08:10 PM
ive got a situation... 68_Gladiator General FSJ Discussion 5 03-02-2008 02:17 AM
possible blow-by situation spaulding General FSJ Tech 4 12-29-2007 01:48 PM
