Old 09-20-2011, 06:46 PM
serehill serehill is offline
Gone,Never Forgotten.
What do you know about a Holley projection
Interested in information pros & cons on the original Holley Projection. I have 2 of them & would like some input from people who actually have some hands on experience. I got them in a trade last Saturday. I've heard all sorts runors about these things. I would like to hear some first hand experience on them. I want to stick one on the Cherk. I have a projection 2 kit for the Commando & would like to get some experience. there's not a lot of dfference between these & the Howell so any input would be appreciated.
Thanks in advance for any input
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 09-20-2011, 07:25 PM
FSJ Guy FSJ Guy is offline
Do you have the analog or digital version? I could never get the analog version to run very well. It was ALWAYS either too rich or too lean.
Ethan Brady
www.bigscaryjeep.com
Old 09-20-2011, 07:39 PM
3 Years, $2k into it, I would never run this again on an off-road rig.
Temperamental and marginal FI setup.
Probably great on a street rig.
I don't like to bad mouth products, but I would ever do one again.
It's intended use was not setup for us (as wheelers).
Your opinion and mileage may vary.
Sorry, not impressed at all.
Old 09-20-2011, 07:43 PM
Fsj Guy
It's the analog Thanks for you reply. I could use all the input I can get. I do have a projection 2 digital I'm saving for another project. I really want to see what this one is capable of. Before I do the projection2. I'm just hoping to see some good input or key suggestions. I also am going to look into a possible upgrade. I've heard you can upgrade the controller to the pro 2.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-20-2011, 07:51 PM
Stupified's Avatar
Stupified Stupified is offline
I ran the analog version on my first Wag a few years back. I wouldn't do it again. When I would get the tune just right, it would run great for about 2 months then go crappy again, tweak for another weekend to get a few more weeks and repeat the process. Finally ditched it for a carb.
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 09-20-2011, 08:01 PM
Tell what you really mean Tad!!!!!!
Thank you sir that's what I'm afraid of. I have a 1405 I think I'll stick with. I just heard good bad & ugly & I wanted it straight form the horses mouth. In Texas they say if you want to here it staight from the horses mouth. Be sure you're on the right end of the horse.
So the bottom line is there was nothing you could do but trash it?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-20-2011, 08:37 PM
If it says anything, I have 1 1/2 complete version of the analog system hiding somewhere in my garage. I'd give them to someone, but I don't know of anyone I dislike that much.
Ethan Brady
Old 09-20-2011, 11:22 PM
Blake Blake is offline
I ran the digital projection on a CJ5 with a small block chevy 350 several years ago.
I never could get it to run right. It did run ok, but definitely not 'great'. A well tuned carb will run much better. Especially a TA.
Old 09-21-2011, 07:28 AM
Stuka's Avatar
Stuka Stuka is offline
The only after market EFI setups that I have seen that work well is the edelbrock TPI setup. Its setup more like that of a modern EFI setup, rather than a weird carb-TBI hybrid setup. There is also the howell setup, which is legal here in CA, a many people here run for that reason. But its based off OEM designs, so its not as picky.
Old 09-21-2011, 09:32 AM
Thanks Guys
So far no good news. I wrote Holley to see if it can be ugraded to the Projection 2 It uses the same TB maybe that will be the ticket.
since I'm going to run one (Pro 2) on the Commando If I cauld upgrade this one that would be the ticket.
FSJ Guy I could use some of you system. I'll pay hipping cost if you want to get rid of it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-21-2011, 10:34 AM
I'd have to find it first....
IIRC, the knobs on the controller unit are a little loose. They work, but they wobble a bit. I might still have a throttle body somewhere, too.
The biggest drawback (I think) to the old Holley system vs. a GM TBI is that the Holley did not have an IAC (Idle Air Control) on it. That (IMHO) really makes a difference in (obviously) idle quality.
Ethan Brady
TBI Help Or Holley Projection CasualGourmet Fuel Injection 18 01-22-2011 08:16 PM
Anyone have the Analog Holley Projection Manual ??? Greg Taylor General FSJ Tech 5 09-22-2009 04:25 PM
Holley Projection question KaiserMan General FSJ Tech 12 11-08-2007 07:48 PM
Holley Projection Problems CheapJeep General FSJ Tech 3 09-23-2006 02:42 PM
Holley Projection system vs a good Holley carb Geoffrey General FSJ Tech 17 03-11-2003 03:02 PM
