Old 04-12-2010, 04:05 PM
ClovisMan's Avatar
ClovisMan ClovisMan is offline
Where can I get a "Full" complete gasket kit for a 360
I looked on BJ's site and Autozone and I see upper kits, lower kits, kits that don't include intake gaskets, etc....
I want a kit that has it all. Anyone know of such a thing? Thanks in advance.
Also, anyone have a link to the correct trans bushing to connect to my TF727?
BTW...I have a 360 with 77k miles on it. It hasn't been ran since 1985. Would you rebuild the bottom-end? The plan is to have the heads cleaned up and have new valve seals installed and replace every gasket on the thing along with a new oil pump, timing chain, water pump, and fuel pump. Compression tests show 138-141 on all cylinders. I had the thing running in my driveway before I pulled it and it sounded great. There was a little white smoke coming out the rotted up muffler, but I attribute that to sitting for 15 years.....
1988 Grand Wagoneer currently in pieces across the shop.
Old 04-12-2010, 04:14 PM
GI-John's Avatar
GI-John GI-John is offline
I looked everywhere also. Every kit I looked at did not include the Intake.
The most complete kit I found was a Felpro one from Rockauto. 100.00 plus the ride. Its on the way as we speak. It included everything but the intake.
I'm sure someone will chime in, but its as far as I've gotten looking through umpteen websites and visiting 4 different parts stores.
YMMV,
John
Just Emptying Every Pocket
Old 04-12-2010, 04:15 PM
thechier86's Avatar
thechier86 thechier86 is offline
o'reilly's had all my gaskets from fel-pro. so far, good gaskets! no leaks, and when i had to undo something because i did it wrong, it was way hard to scrape off the one i messed up, so i take that to mean they're strong.
www.fel-progaskets.com
buckle up, i wanna try somethin...
Old 04-12-2010, 04:16 PM
The Colonel's Avatar
Here is a complete kit minus the intake. I don't think any kit comes with the intake, even engine rebuild kits.
http://www.summitracing.com/parts/FEL-KS2001/
Old 04-12-2010, 04:17 PM
Chumley360 Chumley360 is offline
FelPro's "Full Set" number is FS8266pt4, however the intake gasket and exhaust flange gaskets aren't included. Sealed Power (#2601151) is the same way. IMHO if FelPro doesn't have it you probably aren't going to find it with the intake gasket. Now this being said I'm sure that the next twenty or so replies will prove me wrong. I'd say just get the FS kit and the intake gasket(MS96011/2604008) and call it a day.
1968 M715-Driveway queen/in progress
Old 04-12-2010, 04:19 PM
Artisan's Avatar
Artisan Artisan is offline
try www.bulltear.com, PM the ADMIN and he will set ya straight I bet, he is on this board too, his PM here is jeepsr4ever I would trust this mans advice above most if not all others RE AMC engines....IMO
Regards,
Artisan
1979 Jeep J-10 (Soon to be J-30)
UNDER CONSTRUCTION
Old 04-12-2010, 04:22 PM
GI-John's Avatar
$64.00?!? Thats about 70.00 cheaper than my local parts store!
Old 04-12-2010, 04:38 PM
Lister Lister is offline
I've ordered from this guy before.
http://www.enginepartsstore.com/servlet/Detail?no=336
82 Laredo Mopar 440
Old 04-12-2010, 04:44 PM
Originally Posted by Lister
Good price but I don't know about the quality? Felpro has always made good quality gaskets.
Old 04-12-2010, 04:48 PM
ClovisMan's Avatar
Does anyone know the $50.00 difference between these two kits?
http://www.summitracing.com/parts/FEL-FS8266PT4/
Old 04-13-2010, 12:39 AM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
PAW
JEEP
2005 Ram 1500 HemI
Old 04-13-2010, 05:01 AM
The PT set has the PermaTorque (teflon coated? the blue ones) gaskets, which are supposed to not require (as much?) retorqueing. I presume the KS is a conventional gasket set.
1976 AMC 360 VS. 1984 AMC 360 Tim84j20 General FSJ Tech 7 06-14-2008 08:47 AM
360 exhaust damper gasket?? slackin' General FSJ Tech 3 05-21-2008 02:02 PM
Dana 20 oil pan gasket questions KaiserMan General FSJ Tech 4 12-05-2006 10:25 AM
Using Form a Gasket for the Oil Pan Gasket bfeller General FSJ Tech 6 07-23-2002 07:16 AM
Oil housing gasket icavdiv4fun General FSJ Tech 3 07-03-2002 01:55 PM
