Old 02-24-2010, 08:21 PM
76FSChief's Avatar
76FSChief 76FSChief is offline
Stuck Dash
hello again
Had a few hours today so started tearing apart the dash and wiring. Got the Gauge Cluster, all the wiring and all the little things out (switches, ashtray, clock etc) BUT after taking out the side bolts for the dash it seemed to not want to come out.
So here come the questions:
are there a set of bolts / screws that I am not seeing in the middle of the dash somewhere?
is it necessary to take the dash pad off before removing the metal dash?
I guess it comes down to asking for any information that is available on taking out the dash!!!
any help is appreciated and thanks in advance
Old 02-24-2010, 08:23 PM
there are bolts under the windshield gasket.
Old 02-24-2010, 08:26 PM
jeepmeister's Avatar
jeepmeister jeepmeister is offline
There is usually a bolt behind the steering column also, where you have to drop the steering column to get to it. You will have to remove the windshield to get to the bolts under the windshield gasket.
Old 02-24-2010, 08:30 PM
1983 j10's Avatar
1983 j10 1983 j10 is offline
yep you have to pull the windsheild to get the dash out. i did this on a 77 j truck and i had to drill out a couple of the bolts because of rust.
1983 j10 lwb soon to be a 4.5l stroker AMC 20 rear 44 front 4spd manual in the process of restoring
01 xj 3" and 31's
Old 02-24-2010, 08:33 PM
76FSChief's Avatar
Thanks for the quick responses. Thats kind of what I was starting to think Really wanted to get the dash out today and get some design work done on it while the Jeep is still covered in snow. Will have to talk to some glass folks tomorrow.
thanks again for the quick responses
Dash Removal Thumpszilla General FSJ Tech 7 06-05-2008 11:29 PM
Dash and Interior Lights - LEDs? Thomas792 General FSJ Tech 9 12-21-2007 12:25 PM
FIX THAT BUSTED DASH WITH A NEW OVERLAY!! Chrome General FSJ Discussion 17 12-20-2007 05:37 PM
Dash Swap 8379qtj10 General FSJ Tech 4 11-11-2006 07:00 PM
no dash lights WE B GPN General FSJ Tech 3 11-01-2006 09:26 PM
