Old 10-22-2002, 10:22 AM
JINGA JINGA is offline
Exclamation
I'm in the midst of refurbishing my fuel system. After having the tank professionally cleaned and relined I ordered a new sending unit and a new fuel pickup doo-dad.
The old fuel pickup assembly looked rusty and I figured I shouldn't dunk it back into that fresh and clean tank. The problem with the new one is that there is a little hole on top, about 1/8" diameter. I think it is for a sending unit plug. Except in 1979 the sending unit was separate.
So what's a good way to plug the little hole? I'm thinking a little nut and screw with a few washers and a little rubber o-ring. What kind of rubber will be gas proof?
Thanks for any ideas. Remember, I don't want to ever pull this tank again.
Jeff,
aka JINGA
P.S. I'll try to follow up with a phot when I get the chance.
<a href=\"http://www.prism.gatech.edu/~gtg329d/jeepthumb.jpg\" target=\"_blank\">See a thumbnail of my ride</a><br />\"Once the mind has been stretched by a new idea, it will never again return to its original size.\"<br />Oliver Wendell Holmes
Old 10-22-2002, 11:33 AM
heydave's Avatar
heydave heydave is offline
Maybe you could get it spot welded.
Off the gas tank of course! [img]smile.gif[/img]
Dave Lyons
79 J-10 "The Gorilla"
Old 10-25-2002, 02:40 AM
hehe, yeah.
Actually, since the whole piece looks zinc plated I'd rather not weld on it. (Don't want to disturb the coating.) I'd hate to cause the thing to start rusting in the future. Also, I'd be reluctant to paint over the weld because I don't want the gas to eat the paint off.
I'm thinking along the lines of a plug. Or maybe some fuel resistant JB Weld or epoxy.
Anyone know of something like that? What kind of rubber (for o-ring) is gas-safe?
Thanks,
JINGA
Old 10-25-2002, 03:26 AM
mdill's Avatar
mdill mdill is offline
Gone. Not Forgotten.
I would , get a small bolt washer and nut at the hardware store,
make a small washer gasket from one of the extra carb kit gaskets I have
laying around and then assemble.
Mike D.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 10-25-2002, 06:23 AM
mtn goat mtn goat is offline
You can also use that putty stuff made to seal holes in gas tanks...I think it hardens up well and is resistant to gas.
\'82 Cherokee WIDE TRACK<br />258/T176/NP208/D44/20 Rack of Tad, BIG Orange fender, funny blue hood!<br />I must go and tend to my molecules, they need me to grow big and strong...Polymer Power!!!!
Old 10-25-2002, 01:52 PM
Those are both great ideas.
I like the putty stuff because that sounds really easy. I was hoping something like that was available, but wasn't sure.
The nut and bolt is what I was leaning towards (because I like nuts and bolts I guess) but was concerned about what type of oring to get (and where?). But your idea about the carb gasket is an excellent suggestion.
Thanks gentlemen,
aka JINGA
Old 10-25-2002, 02:51 PM
Why don't you return the pick up for the correct part??? I got a new one, and it didn't have a hole in it. Try MTS in Dubuque Iowa. They make the poly replacement tanks and will sell sending units and pickups.
Old 11-04-2002, 03:24 PM
hmm, tried to post this earlier and it didn't seem to "stick."
Anyway, I called up the guy from MTS and talked to him about the hole. He said his has them too. (????)
Turns out it's easier to manufacture this way as it's more versatile, etc. (Something about CJ's.)
He says what he does for the hole is to run a 1/4" nut through it with a few rubber washers.
Okay. I'm back where I started.
Thanks for the help guys,
AKA JINGA
