  #61
Old 02-26-2022, 01:51 PM
linkage controls throttle valve in transmission.
controls line pressure/shifting
run without one and trans. will slip, create heat.
clutch packs/bands will wear rapidly.
it'll also shift very poorly.
they can pop off, easy to make it correct, I wouldn't rely on an rtv booger.
Old 02-26-2022, 02:28 PM
Huh, good to know. I'm not worried about it falling off, it was still work to get the plastic circular thingee on there, goop was just added measure just in case. I'll look into the solution you provided there though.
--Rob--
My build thread:
My Howell TBI Install How-To:
Old 03-09-2022, 09:56 PM
Micull Micull is offline
Rob - Thanks so much for documenting your install....so helpful. I've just received my kit and will be installing this weekend. Quick question - what did you do with these connectors that plugged into the original carburetor??
20220309_224802 by Michael Cullum, on Flickr
Old 03-10-2022, 09:24 AM
The large long curved pipe you have circled on the left is the PCV, which is shown in the diagram I have in post #43. It goes to both port-A and the vacuum canister purge signal nipple.
The one you have circled in the middle isn't a vacuum connection. Take the 2 bolts off and you'll see it's merely a bit of piping that assists in warming the choke a bit quicker than it otherwise would without it. You can actually remove the entire thing, as there are no provisions for it with the Howell kit.
--Rob--
My build thread:
Old 03-10-2022, 10:45 AM
Got it. Thanks.
Couple of questions on my Howell TBI Blake Fuel Injection 2 03-26-2012 03:17 PM
Scored an AMC 360 Howell TBI from a yard today! Blake Fuel Injection 4 01-05-2012 07:49 PM
Howell TBI or Holley TBI + Igntion Hemp Fuel Injection 2 03-25-2010 10:41 PM
Howell TBI Preliminary Preporation SnowShoe Fuel Injection 39 02-06-2010 11:34 AM
Strange thing with my Howell TBI (kinda long) ne715 Fuel Injection 0 04-13-2008 04:48 PM
