-   General FSJ Discussion (http://www.ifsja.org/forums/vb/forumdisplay.php?f=11)
-   -   what did u do to your jeep this weekend (http://www.ifsja.org/forums/vb/showthread.php?t=88982)
KansasWoody 03-13-2010 08:31 PM
replaced rear brake lines, and taadaa imagine that! now i have 4 breaks instead of 2!
x6xdemonx6x 03-14-2010 01:50 PM
cussed at it alot while pulling its tranny
janie 03-14-2010 05:03 PM
Dropped this:
So we could drop this beast out of the way:
Think I need new tierod bushings?
All this just leaves me hungry for more.
rocklaurence 03-14-2010 06:11 PM
Tightened up the oil pump bolts on the J15 and ATT its not leaking:eek:
jsinajeep 03-14-2010 07:34 PM
Originally Posted by janie
Dropped this:
Uum, is that the tie rod:confused: mine look different:D Oh, I think I see the rod under all of that dirt.
You wouldn't want to get rid of that dirty old looking winch would you:D
krek 03-14-2010 07:43 PM
I put together my TadRack!
bigblock91 03-14-2010 08:12 PM
i dug mine out of the moth balls and started ploting and planing... muhahahahahaha.. next weekend the carnage begins :sawzall: :sawzall:
CJ the noisemaker 03-15-2010 12:30 AM
I fixed my exhaust and bashed out my passenger fender.
More info in my restoration page.
joker7037 03-15-2010 01:27 AM
Changed the spark plugs. :D
homerj40 03-15-2010 10:38 PM
J2000 Hybrid
Pulled the (Gack! Cough! Hurl!) spreadbore Holley out and installed a new Jet rebuilt Quadrajet on the Buick 350.
YEAH MAN!!!!!!!!!!
Now it's a hybrid - Burns gas AND rubber!
trailscape 03-15-2010 11:16 PM
I checked all the fluids and add a couple fire extinguishers, then got bored and hacked in some hood louvers. Lastly, I hit 55 for a few seconds. I'm still alive too which is impressive given how bad the thing was vibrating. Something to figure out next year...
Oh yeah.. Also cleaned up the instrument cluster and cut out a piece of plexiglass to replace the lenses. Painted with duplicolor bedliner spray..
It's off to storage this week.
kwai 03-16-2010 12:32 AM
front and rear brakes, master cylinder, brake hoses, shocks, steering stabilizer. More parts on the way for next weekend.
HD_JEEP 03-16-2010 10:26 AM
Got the damaged fender off to replace.
Donor fender from my 83 Brougham parts jeep. :o
Now she has a sad face. This hurts me more than her...:(
91G-Dub 03-21-2010 12:12 PM
I ran a 1/2 can of Seafoam through the carb, hope this helps with what I think might be some condensation in the fuel tank. Smoked like the devil after I did it. Time will tell.
Also got out a few rattle cans of paint.
Truck box
Before
After
Did some painting on the tailgate too:
Before/After painting with Rustoleum Anti-Rust/During painting Jeep logo/Final product:
This is a 20 foot paint job
Badawg 03-21-2010 12:17 PM
cleanup after last week's BAJA TREK. I somehow managed to lose a front hub flange cover... guess it rattled off.
Rompn 03-21-2010 03:57 PM
I finally got the rest of the 38's on, need some more lift in the back to fit them though, started bolting the entire front clip back on and also started hooking up some wiring.
I started two threads that I could use some opinions on. First one is in regards to the core support body bushings... http://www.ifsja.org/forums/vb/showthread.php?t=118983 , second one is about hooking up factory wiring to the Chevy 350 swap I did... http://www.ifsja.org/forums/vb/showthread.php?t=118995
Lastly, here is a pic of where we are as of today...
janie 03-21-2010 04:13 PM
Not a whole lot. Still cleaning up/out the interior. So much more to do.
davidrodriguez6769 03-21-2010 06:54 PM
Rained all day;got C/B wired up,and tested,ran ant cable now need to mount antenna .maybe tomorrow will be more productive.:D
Austin 4x4 03-21-2010 07:25 PM
what did i do? well um?
:sawzall:
78J-10 03-21-2010 07:37 PM
Well had some good and bad point to the weekend. New rear shackle set up arrived form ruff stuff. THe new front shackles form BJ's didnt but i was not expecting them too. Bought my new rear 63" springs on sat and fishined rebuilding the front axle.
Got the front axle installed on the jeep sat after noon.
(will have pics later)
All was going good up till this point. Put the axle in and tried to jack it up to get the roller tires on and the front shackle broke :( so i halfass welded it back on enough to hold the axle. :banghead:
Then we moved to the rear and the new to me springs had a crack int he main leaf from trying to impact the old bolts out :mad: :banghead: :banghead: :banghead:
So the rear fabing will have to wait for new springs.....
All in all atleast i got something done this weekend and something is better then nothing in my book. Had to sit down with some of the guys who helped me after the whoel rear spring incident and have a beer to relaxe :alc:
