-   General FSJ Tech (http://www.ifsja.org/forums/vb/forumdisplay.php?f=10)
-   -   OVERDRIVE - BOLT ON - AFTER MARKET (http://www.ifsja.org/forums/vb/showthread.php?t=190837)
devildog80 07-15-2022 03:33 PM
Thread for general information as I had the thought to find one for my rig.
Overdrive unit available (for hiway OD only-which is what I want) bolts on back of the existing TC, requires a new rear only drive shaft, and turns the 727 3-speed into a 6-speed.
The bolt on unit electronically shifts in manual or auto shift mode with 1/2 gear increments, to the full gear shift of the auto trans.
So your 3-speed will shift like this
1 to 1-1/2 to 2 to 2-1/2 to 3 to 3-1/2
This is the site for Dodge 727 3-speed info
Dodge 3-Speed Auto - Gearvendors
Go here for more info-
info@gearvendors.com
Looks like the bolt on unit is right at $3200, then need shorter rear drive shaft, as unit is about 12" thick.
Best part about it, they have an exchange program so when you change vehicles, you get credit for exchange to different unit.
Units handle up to 1200 hp, then need hydraulic modification up to 2000 hp.
Looks promising....just need to find those money tree seeds and get that sucker growing :)
Honestly....would rather spend this kind of money for an O/D unit, rather than FI.
wiley-moeracing 07-16-2022 07:09 AM
If you are doing this to save gas, it is not worth it, that $3200 will buy a lot of gas over the years, not to mention your labor and other parts needed to do the install. You could do a transmission swap that has a overdrive in it also.
devildog80 07-16-2022 10:56 AM
Not to save gas, as there are still a lot of dead dinosaurs down there for me to burn through, but I like the reputation of the 727 transmission. Thinking the O/D would just make it nicer to drive for towing on the road, and if I save gas in the process, ok.....and working on that angle separately.
We currently are using my dads 16 ft Scamp camper, which the GW will be pulling when ready, which is less weight than most flatbed trailers empty.
So when I get the GW road worthy and driving, will see how it performs, and where improvements are needed.
Seems as with most add on devices for these old rigs, to make them more like our modern vehicles we are spoiled with, anything costs thousands of dollars. At the stage of my build, watching what everyone else is doing, to try and get my money best spent when the time comes.
Thanks for feedback, and keep burning the dinosaurs :)
wiley-moeracing 07-16-2022 01:58 PM
Ideally, a different trans with the overdrive in it and a lock up convertor and changing gears in the diff to 373 will make it more enjoyable to drive. Something I may get around to one day.
fastjeep 07-18-2022 08:48 PM
Have a 6L80 trans from late gm, bolted to a 208 transfer. Only 1.5 inches longer than 727/208 with Advance Adapter to 360. With a 4.02 1st gear and 2 overdrives will drop cruise rpm's about 1400. My J10 has 4:10 gears with 33" tires so current cruise rpms about 3400. Will have about $2600 in parts to convert. I figure with that 1st gear ratio will help towing starts also.
Mikel 07-19-2022 06:33 AM
Hi - How do you plan on controlling the 6L80?
fastjeep 07-19-2022 08:38 PM
Zero Gravity Performance has a controller for the trans, needs a tach signal and an TPS to use.
devildog80 07-20-2022 12:43 PM
So if I do not have a TPS on my '84 GW, I would need to install one just to use this O/D?
fastjeep 07-20-2022 08:38 PM
Yes you can install one on throttle linkage. I have Fitech injection and they have patch cables avaliable to operate 4L80 trans as so do Sniper and other throttle body injections do. Most are looking into getting able to do the 6L80 trans but not made jump yet. To use NP208 transfer must install 32 spline input gear to match trans output spline. There are 3 different output shafts on the 6L80 trans, a 2wd slip yoke, a 4wd shaft out of truck and a fixed yoke 2wd. I used the 2wd fixed yoke that requires some modification to shaft and install 2 small plugs in rear case to seal trans fluid from tail housing and a shaft seal that Advance Adapters has a kit to do. One thing that can be done also with the trans controller is a kit to do paddle shifter on steering wheel which I am thinking of doing.
devildog80 07-21-2022 11:57 AM
Wow....way too much modernizing for my taste.
Just a simple mechanical auto w/OD!
Mikel 07-21-2022 04:01 PM
Thanks
