Ok, I'm finally making some progress on my build. Got the engine back from the machine shop and got it put together. Using the Speedmaster stainless, roller, adjustable 1.8 LS set. Had to machine off .125 from the pedestals that come with the kit and since the kit comes with metric bolts you will need to get some 5/16 x 1-3/4 so they will be the correct length. Then I will have to order 8.00" pushrods. Everything looking good so far.
LS rockers
David "If all else fails, read the instructions."
83 Wag Lt,BJ's 6"lift,360/727/Pinned229,D44/trac-lok,AMC20/lock-right,35/12.50 Baja MTZ,Pro-Jection EFI.
10$ NP229 fix http://www.ifsja.org/forums/vb/showthread.php?t=2520
Sweet! Post some pics, too!Chuck McTruck 71 J4000
Because the ones that you are referring to are 4 times the cost of the ones I am using and my OEM valve train needs replacing anyway so there is very minimal additional cost in replacing my worn out stock stuff with new, adjustable, roller rockers. And most importantly....because I can.David "If all else fails, read the instructions."
Originally posted by wiley-moeracingMore power to you, but some of these readers will think it some miracle power adder for super cheap which it is not. Be interesting if you post in the end with true cost of time, labor, machine work and parts and compare so we know.David "If all else fails, read the instructions."
Take it easy friend, we all have little projects just for fun no matter cost or time. There are people reading this looking for a miracle power adder for cheap, reading this post from the beginning, there are all kinds of tinkering that can be done, which can be fun if that is your thing. Again, have at it and share what you come up with so you can pass the info on to the next guy.
Originally posted by Chevelleguy...REALLY keep track of the TRUE cost that we have in them...Chuck McTruck 71 J4000
I'm at $50 for the LS rockers off ebay, $15 for the raw material from McMaster. Hardware is borrowed from work. Lunch hours machining instead of playing on the internet: "free".
Anyway, seat of the pants feel after advancing the cam 4 degrees for more idle vacuum and installing the higher ratio LS rockers: it feels slower, but hey at least I have enough vacuum at idle to activate 4wd, and it doesn't stall as much shifting out of park.
Last edited by Chevelleguy; 09-23-2021, 06:36 AM.David "If all else fails, read the instructions."
Originally posted by wiley-moeracingDo they clear you valve cover?David "If all else fails, read the instructions."
LS Rockers
After using a valve 4.900 long and starting the sweep at the center of the valve stem, I will use a valve around 5" long in all future LS rocker arm swaps.
The LS rocker travels across the valve stem in a wide ark, therefore the rocker has to start its sweep on the intake side of the valve stem.
I am setting up a pair of heads next week and I will try to get some pictures up
