Ammeter or voltmeter?
  • Ammeter or voltmeter?
    I getting ready to pick me up a 3 gage setup, and know the difference between an ammeter and voltmeter, but which should I get and why? Dennis
    Starting to miss the addiction!
    ammeter measures amps, voltometer measures volts. Screw the ammeter, they are known for fires from having all the current run through them. Main reason no newish cars ahve them.
      voltmeter.
      Ken's:
      1966 Super Wagoneer
      5.7L 2BBl. Th700R4. NP-208. Opens. 3.31s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
      (Soon to be TBI)
        Voltmeter...I would rather know how much voltage I have than if the alt is charging.
        IMHO it is easier to tell if there is a problem with the charging system.
        My license plate says "Crazy" not stupid
        1971 J4000 Buick 350/TH400 "Terra"
        *STATUS Down as a summer project*
          definately get the voltmeter
          1985 Grand Wagoneer \"Bertha\" (currently undergoing major reconstructive surgery)<br /><br />Pioneer & Sony Audio<br />TFI<br />Pair of Hella 500s (not working now)<br />Flowmaster Delta 40 Series & Hack Job Exhaust<br /><br />Mold-infested carpeting <br />*smells ggggreat!*
            Voltmeter. Dunno why you'd ever need the amps read anyhow. BTW ..WTF does the factory gauge try to say in our jeeps anyhow. its a -60 to +60 ranged gauge where 0 is where the needle lies most of the time.. IS that measuring the draw or something? Never quite got that...
            83 \'Wag<br />AMC 360/ MSD/ Cam/ 650 Holley 4bl.<br />4\" Skyjacker w/35\" MTR\'s<br />plasma cut fenders <br />4.11 with posi<br />Durabak interior<br />Custom front bumper/tank
              Guilbeau's my Name, Electronics MY Game...
              Ok, the Ammeter in our Jeeps are in acutallity a Battery Charge/Discharge Rate Indicator.
              The alternator is hooked up to one side of the Amp gauge, the other side of the amp gauge goes to a splice which draws electron current flow from the Battery itself. That is why the fusible link is on THAT side of the Ammeter. The battery will supply power to the Ignition Switch, the Horn Relay, the lights, and a few other items.
              What the ammeter is acutally measuring is the Alternator output to the battery when the Alterntors Regulator circuit tells it to start charging the battery due to low battery voltage. This is what you see when just after starting the vehicle and the Amp gauge swings to the positive to something around 40-60 Amps and then slowly tapers off to the center or 0-Amps after about a half mile or so or sooner depending on the size of the Alternator and the size of the Battery.
              Now, when the engine is not running, you can turn on all the lamps, honk the horn etc... and the Amp gauge will read negative because the ammeter is no longer supplying current.
              When the gauge reads somewhere around zero, it simply means that the ammeter is keeping up with the load placed on the battery.
              By the way, those of you who bypass the ammeter by placing both of the connection at the ammeter on one side of the ammeter terminal, really need to place a fusible link on the Red Wire from the Alternator, because you have now provided a parallel path for current to flow, so if the fusible link on the yellow wire opens up, the red wire is still gonna try to burn your Jeep to the ground.
              Circuit breakers are a much better idea for about 40 bucks retail, you can get a 100 amp resettable circuit breaker that is sealed and can be mounted on the firewall right next to the solenoid. Now you are protected...
              Joe Guilbeau<br />1983 Cherokee Laredo WT (SJ-17), 360/229/727/D44/D60 4.10 Gearing, 8-lug hubs, Edelbrock Performer w/EGR Intake, Mallory Unilite Series 47 Photo-Optic Infrared Trigger Vacuum Distributor, Mallory Surge Protector, Mallory Promaster Coil, Holley Pro-Jection TBI 502-Analog, FlowKooler High Output Water Pump, Staggered 4-Core Custom Industrial Radiator, HD Fan Clutch, Dual Electric Fans, CS130 Delco 105-Amp Alternator, Oil Bypass Mods at Rear of Block and Distributor Oiling, Superlift 4\" Suspension, Rancho RS5000\'s, Hi-Tech 31\" Re-Treads, Aero 33 Gal Tank w/Skid Plate, Custom Rear \"Longhorn\" Bumper
                Omg, Awesome info man, thanks alot. I'm a smater person for knowin ya!
                  cool you're in San Antonio too.. I know who I'll be callin on for electricity probs now......
