If I found a early 80's model cherokee with an np208 and a T-176 4 speed manual tranny, would the tailshaft from my 727/np229 setup still fit? I'm thinking about swapping hubs, transfer case with linkage, and possibly the rear drivesaft into my '89 waggy.
NP208 from a 1983 Cherokee with a T-176
You don't want the 4 speed?82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
Not really, no. I'd have to switch out the pedals and then prolly mess around with the flex plate and mounts since the cherokee is a 258.---------------------------
Campin'/Wheelin': 89 SJ Wagoneer 360/727/np229
Daily Driver: 05 WK Grand Cherokee 3.7 v6 - nv140 single speed
ok, so you are asking if you can bolt a np208 that was attached to a manual tranny to a 727? The answer is yes.82 Cherokee WT ? SFwith Alcan/agr box/Borgeson shaft/ 401/performer/Holley TA/HEI/BeCool/727/ALTAS(2.0/2.72/5.44)/D60 Snofighter(Yukon Zip,hubs,stubs,4.56)/14 Bolt (FF,BF shave,Discs, ARB,Artec Truss)/MTR 37/Corbeau Moab Seats /Hella/tuffy console/sliders/custombumpers&roll bar/WARN 8000/steering brace/CO2 Tank/dual batts/custom TCskid plate
And yes you will need the driveshaft swapped as well. But it will all bolt up. Don't forget to get the shifter and linkage for the Np208 and install it also ( Look for "J10 Mikes" shifter mod for pics and write up),unless you just like having the floor mounted flag shifter.Tom Gibson
1980 J20 Utility bed truck. Factory cab and chassis truck. Many new mods for it but it will look all stock.
1985 J10 nothing special just a nice clean stock truck.
2017 Challenger. Very jealous of the Jeeps.
