Update from previous looking for cheap rear body mounts: body mounts
Upon closer inspection the rear frame bar is deteriorated more in that area, almost the size that there will be a day when the bushing will fall through the frame. Has anybody replaced the rear frame section. I think its just held in with BFR, (Big F-ing Rivets).
I might try a couple things like going to home depot and buying a few lengths of 90 degree angle, in either steel or aluminum. This could be used to sister on either side of the deteriorated area and then as said before in old post slide in a hockey puck after you drill a through hole.
My remaining questions are:
1.) Bolts, where is access on the top side. I've had the bumper off, carpet pulled back, still can't see it. Maybe I need to look for it again.
2.) If I break a bolt off how am I going to replace it?
3.) Can the rear frame section be replaced, or even fliped to use the other side? hmmmm
Any been there done that experience more than appreciated.
[ November 18, 2004, 08:39 AM: Message edited by: Jeepeta ]
