Whenever my tank is full or near full I have a gas leak coming from somewhere on top of the tank. Is there a vent on the top thats come loose, or have I rubbed a hole in it?
Gas Leak
IIRC theres 2 or 3 lines (depending on year) coming out of the top. Theres a short piece of rubber line connecting them to the hard lines that run down the frame.Jeff
'43 cj2a
'51 Willys p/u
'51 Willys Parkway Conversion
'68 Panel Delivery
'74 CJ5
'75 J-20 Wrecker
'75 J-20 Cummins service bed
'77 J-10 p/u
'79 Cherokee
'88 Grand Wagoneer
'98 Grand Cherokee
Sending units up there... I would concur with above to check your hoses, mine were pretty rough shape.______________________________________
rusting away...
Firewater- 1978 J10/401
STATUS: tore up and beat down
Originally posted by rockjeep44Please don't run a cherry bomb. I want to punch babies every time I hear one of those things.
What year is your J? If it has a plastic tank, it most likely has a crack in it where the side rounds over to the top. Mine cracked on the driveshaft side, where the side meets the top, in the middle. Look for gas stains too. If you're lucky it's just a leaky hose.
JR[quote] "How does someone from Iran have a BJ's Offroad sticker but I can't seem to get one sent to New Jersey???!!!"
1966 mustang fastback
'07 Dodge Charger 3.5
Originally posted by Headhoncho... If it has a plastic tank, it most likely has a crack in it where the side rounds over to the top. Mine cracked on the driveshaft side, where the side meets the top, in the middle....Brad Smith
79 J20
360/NV4500
D44/D60/3.31s
past rigs -
86 J10
80 J10
79 Chief
