i just did a swap and installed (buddy did most work) a 360 with cam, edlebrock carb and manifold with some other tweaks. It had 3k on rebuild and it rolled once. it sat for about 1.5 years. the prev owner took good care of it and it ran fine. the cold start was funky but it ran ok once it was up and warm. i might also add that it has a leak in the left manifold/exhaust gasket which will be fixed soon. my buddy noted the cold start issue and said he felt the black choke unit on the side of the carb was supposed to have a ground wire. it only had the slip on positive wire and when he ground it, he said the butterfly closed or opened right up. since then when cold start it revs up and idles way too high. the oil pressure is up around 60 and it sounds like the pedal is half way down.
this spooks me as i know cold and revs that high dont mix. if you tap the pedal again too soon idle drops and it rumbles and farts. if you let it idle high long enough and tap it, the revs come down but it takes about 10 plus minutes in 30 degree to idle smooth. it also will surge a bit at low speed acceleration kind of like when you have a bad plug wire that is wet. at steady throttle around 20 mph it will surge slightly. It also has the HEI distributopr. Soooooooo question is, any ideas as to what might be happening? It was a recent install so a line or something could be bad etc.
The other question is I have been told to cold start, turn key on. Press pedal once and release, then start it. When I do that it starts bang right away. I saw a paper from wagonmaster that showed cold start to be turn key on, push pedal all the way down and release and hold it have way, then start it. What is the proper way and does the fact it has edlebrock carb change anything?
Thanks in advance
Thanks in advance
