Chasing down a miss. Want to avoid a shock
  • Chasing down a miss. Want to avoid a shock
    Ok, pull each plug, while running, to check for a possible miss.
    Techniques? I have done this, and received a big shock. Now, due to my recent heart trouble, I am hesitant to risk it.
    I used rubber handled pliers etc. This always seems silly, but I do think the technique is solid.
    So, make sure I am standing in water first? hehehe..
    Seriously, what do you think?
    Louise will appreciate it.
    Ernzo
    84 GW 'Louise' Bone Stock.
    Runs like a Champ.
    First Place Winner Ouray 2002 'Lowest Jeep'
    'Homer" 1949 Dodge Wayfarer Roadster
    (Both named after my Great Grandmother, Louise Homer)
    1978 Dodge B300 w/Chrysler 360 - 727
    Denver, Colorado
    In all seriousness, rubber gloves and insulated hose pliers. They're like extra long needle nose with the ends bent into a hose shape.
    http://www.thetoolwarehouse.net/shop/SUN-3705.html
    I found the set I've got at Harbor Freight for about $12
    Jeep Grounds
    RRV Homepage
    1987 Grand Wagoneer
    AMC 360/TF727/NP229
    1999 Wrangler Sport
    4.0L/AX-15/NV231
    ?Freedom is never more than one generation away from extinction? by Ronald Reagan.
      One way to make this easier, pull the plug wire before cranking the engine. Then while holding the wire with insulated pliers, move it to the plug. As soon as it gets close to the plug it'll start jumping that gap and if it's good you should here the immediate change. Might be easier than trying to pull it while running. (have to admit, never done it this way myself)
      '84 Wag, 360, 727, 229, stock 177k
        Pull the wire from the cap, not the spark plug. When you pull the wire from the cap, you are now holding a dead wire. When you pull it off the plug, you are now holding a live wire looking for a ground!
        David "If all else fails, read the instructions."
        83 Wag Lt,BJ's 6"lift,360/727/Pinned229,D44/trac-lok,AMC20/lock-right,35/12.50 Baja MTZ,Pro-Jection EFI.
        10$ NP229 fix http://www.ifsja.org/forums/vb/showthread.php?t=2520
          Pretty smart for a Chevelle Guy!
          Good idea.
            Thanks, you learn a thing or two after 22 years of wrenching. Like don't get hit by an MSD ignition.
              spend the $20.00 and pick up an old school tune up meter, with cyl shorting capability.
              Mike D.
              Home of ADHD project list
              1977 J-10 Honcho 360-T15-D20
                I put a long wire with a clip on one end and attached the other end to an ice pick, then I can slid the ice pick between the boot and the wire to kill each plug.
                Rich
                90 GW DD
                00 Dodge 2500 diesel
                78 3/4 power wagon army surplus
                68 Charger R/T (long road ahead)
                35 Plymouth
                  I've used my inductive timing light. Hook it up to each plug wire as close to the plug as possible, then pull the trigger on the light. IShine the light on a dark surface and see how regular it is. If there is spark, it will set off the light. If it is a good regular spark, the light will reflect that. Plus, timing lights come in handy for setting the timing
                  88 GW 4" lift, 31's, Razor
                    And they make a real neat strobe!! LOL!
                    Jeep Grounds
                    RRV Homepage
                    1987 Grand Wagoneer
                    AMC 360/TF727/NP229
                    1999 Wrangler Sport
                    4.0L/AX-15/NV231
                      Thanks, great tips. I will look for the hose pliers (I did not know about them!), and hook up the vacuum guage and check this out.
                      I am looking for an "old school" tune up meter, but no luck! I love "old school" tools! Ebay as some heathkit meters, but I do not believe they offer that feature.
                      I recently got a perfect condition Sun Timing light / dwell meter combo for a buck at a garage sale! Before I could use it, some reprobate stole my tools, including the light...!
                      Ernzo
                      Runs like a Champ.
                      Denver, Colorado
                        Run it in the dark with the hood open (disable hood light if it works) and you can look for arcing wires where the spark jumps from the wire etc. Had a miss on my chevy, looked liked a disco party at night under the hood
                        Honey?? What happened to the savings account? You bought a Jeep what??
                        86 Grand Wag Stock with Bulltear HEI
                          I have done that in the past, will try again. I searched on Ebay for a "cylinder shorting" engine analyzer, and while there are plenty of units listed, I am not familiar with them. Anybody have one they like?
                          Ernzo
                          Runs like a Champ.
                          Denver, Colorado
                            This is the most shock-proof technique, the only drawback is it bypasses the wire, so you are not testing for a bad wire, you would have to ohm it. If you pull the wire off at the plug, to avoid getting shocked, keep your other hand off the truck, and don't lean on the fender. In order to carry current you need to complete the circuit. If you only touch the wire, the current will not travel up your arm.
                            Sleep, Eat, Jeep, Repeat...
                            "I need Another Jeep!"
                            "The streets will flood with the blood of the non-believers!"
                            "Of all the things I've lost, I miss my mind the most!"
                            "Nothing makes a person more productive than the last minute"
                              Try Cylinder balance analyzer
                              The one I have is a MAC ET985
                              Mike D.
                              Here is an old auction http://cgi.ebay.com/ebaymotors/Mac-T...mZ250209696109
