blue streak points
  • blue streak points
    Hi, anybody use these, know the part number or where I can get them?
    Ernzo
    84 GW 'Louise' Bone Stock.
    Runs like a Champ.
    First Place Winner Ouray 2002 'Lowest Jeep'
    'Homer" 1949 Dodge Wayfarer Roadster
    (Both named after my Great Grandmother, Louise Homer)
    1978 Dodge B300 w/Chrysler 360 - 727
    Denver, Colorado
    You can look up parts by application on their website. Blue Streak is made by Standard Motor Parts. They are owned by a bigger company - name I forget, But if you google Standard Motor and Blue Streak, it will come up.
    Now the trick IIRC is that Standard Motor adds an X at the end of the part number to identify Blue Streak parts.
    If they don't make the points for the application you need, check out the Neihoff brand (owned by same corporation IIRC). I just bought a Neighoff cap and rotor for the '85 GW (no Blue Streak Cap and Rotor for this distributor). The Neihoff cap and rotor were made in the USA - All brass terminals and nice housing. A little bit more flashing than I would have liked to see. The cap box said Ultra but the part number was just plain ole FF77. The rotor (FF44) wasn't quite as nice. Brass tip, but no brass plating on the contact spring. The old Echilin (NAPA) rotor was better and the cap was equal. I'm just not sure the current Echilin stuff is as good quality. It might be - just don't know. Anyway, I was very pleased with Neihhoff cap and rotor. Much better than a lot of what I've seen out there.
    '85 Grand Wagoneer
    360 727auto, NP229
    body by beer (PO)
    carries wood inside
    no "wood" outside
    My other car is a fish
      Thanks! I found Blue Streak Canada with a part/part number look up.
      Ernzo
      Runs like a Champ.
      Denver, Colorado
