Steering Part ID help PHULEEEEZE.....
  • SCscoutguy
    replied
    I am not sure if this is going to help or not but I did some google searching and on this Bronco message board they say their steering box is 36 spline. Your 31 spline shaft might work with this joint. It might be worth looking into getting a bronco rag joint?
    http://www.fullsizebronco.com/forum/...ad.php?t=54503
    Leave a comment:
  • Ristow
    replied
    Originally posted by Crazy_Jeepman
    Different
    they used a different coupler?
    Leave a comment:
  • janie
    replied
    Fellas, thanks so much for all the help. Definitely appreciated. I've decided I'm gonna save us a bunch of heartache and just take the J-20 box back.
    We've gotta have this truck to ready to roll out of here by Friday for the axle rebuild.
    We'll pick one up for a J-10 and call it done.
    Leave a comment:
  • Elliott
    replied
    Originally posted by Lindel
    Would on of Flaming River's steering shafts work? IIRC they use a u-joint, not the fabric/rubber coupler.
    Yeah, for $279 -vs- $12 though.
    Leave a comment:
  • Elliott
    replied
    Originally posted by Ristow
    i've looked everywhere. no dice.
    y'know,gm used saginaw steering.maybe hit a boneyard,look at a K20.
    I was doing that yesterday, maybe if you found one prior to '77, two that I checked from '79 and '82 (a C30 &C20) were the same as the later year Jeeps. Somebody here on the forum must be parting an early Jeep though...
    Leave a comment:
  • Crazy_Jeepman
    replied
    Different
    Leave a comment:
  • Ristow
    replied
    Leave a comment:
  • Lindel
    replied
    Leave a comment:
  • Billy Bob
    replied
    here are pics of the measurements
    Leave a comment:
  • JeepsAndGuns
    replied
    I ran into a problem like this when I swaped in my steering box. Its the large piston J20 style. But I think mine came off a hummer or something. Got it off ebay, rebuilt. But it had larger splines than my old box, my old rag joint coupler would not fit. Same problem your haveing. I ended up haveing to buy a U-joint at a local speed shop and had it welded to the steering shaft after I cut off the old rag joint part.
    Leave a comment:
  • Elliott
    replied
    .602 at the widest area?
    Leave a comment:
  • Billy Bob
    replied
    No such luck!
    The shaft is larger on the new J-20 box, and the shear pin is larger as well. SO,...no go!
    Leave a comment:
  • Billy Bob
    replied
    Originally posted by Elliott
    What's the chance that pin drives out so you can swap the splined sections?
    Also there are only 17 splines on that rag joint flange, but more on the input it came off of, should be ~25.
    Then, what did you mic that 31 spliner at, 0.625 or what?
    Mic'd @ .602
    Spline count on the original shaft is 25
    I will see if the pin will drive out. The splined sections appear to be of the same dimensions on the shaft
    Leave a comment:
  • Ristow
    replied
    i'm lookin' janie....i have that coupler you need,but finding it in the mess,after all the scrap hauls,may be tough...
    Leave a comment:
  • Elliott
    replied
    Leave a comment:
