I've searched here, there, and everywhere. I can't seem to find an answer to what I'm asking. I'm doing the TFI upgrade on my '90 this coming weekend. I plan to use the Echlin ICR22 resistor when I install my coil, because at buildyour4x4.com, they recommend it (so I don't burn up my stock module with 12 volts). That's all well and good (even though the Tech install on the IFSJA homepage says not to use one).
MY QUESTION IS...
Why can't I just use the 2 wires that the original canister coil is using to hookup my new TFI coil?
According to buildyour4x4, I'm supposed to find a keyed power wire, etc.
Hook up the TFI coil
"You?ll need to find a power source that has 8-12 Volts when the vehicle is running and zero when the ignition is off. This will be the power source for the coil. In Ford?s original TFI setup, only 8 Volts are provided to the coil. However, there is some general consensus that the coil can safely handle a full (12 V) power supply. Your stock ignition module could very likely fail if you use the full 12 volts, so we recommend using only 8 volts. If you want to run it with the lower voltage like Ford did, then you would simply put a resistor wire (see the part numbers chart above) in between the coil and the (+) power source. We chose to run the full 12 Volts directly to the coil for maximum power output. This resulted in our stock (OEM) coil becoming uncomfortably hot, and we ended up swapping out our ignition module with a prototype for the Mutant ignition module that can run on the full 12 volts. We recommend either upgrading your ignition module, or using the resistor wire to reduce the voltage. You?ll want to study the wiring diagrams posted below until you are comfortable that you have found the correct wires to splice into before you hook up your system. Once you have found the switched power source, splice it into the red wire on the TFI coil plug connector. Splice one of the green wires on the TFI coil plug connector to the green wire that comes out of the ignition module. The other green wire is not required, and can be cut off, or it can be left for future use in wiring up a tachometer."
PLEASE keep the answer fairly simple, as I don't do so well comprehending what I can't "see". TIA
MY QUESTION IS...
