1989 GW. Pretty clean and a great runner......
Problem: When using the turn signals, left and right, The volt meter dances downwards and in time with the signal.
Battery is new, connections are clean. Alt is putting out 14.7 consistently even when the volt meter gets erratic.
This only occurs when the turn signals are used. Volt meter is not affected when turning on lights, fan, or any other
accessories, windows, power locks, ext, ext.
Does anyone know what is happening and what is the fix?
Is there a schematic on the ground locations for this vehicle?
I am not really good at diagnosing electrical.
I could clean up the grounds if I knew where they were.
I did replace the big ground from the motor to frame when I rebuilt the motor.
Thanks for reading..... Tim.
