I'm in the process of putting the drive line back together and swapping cases. This wag has 3.31 gears(still not low enough to get the pig moving) so I'm guessing I need to reuse the drive gear out of the failed case which matches the 3.31 gears. Is that it, or is the worm gear on the tail shaft a different pitch.
NP229 speedo drive gear.
Sould be just the diven gear that needs to be changed.David "If all else fails, read the instructions."
83 Wag Lt,BJ's 6"lift,360/727/Pinned229,D44/trac-lok,AMC20/lock-right,35/12.50 Baja MTZ,Pro-Jection EFI.
10$ NP229 fix http://www.ifsja.org/forums/vb/showthread.php?t=2520
