I energized my idle stop solenoid, it works just fine but how in the world is it supposed to make contact with throttle contact? I see the adjustment bolt and where the solenoid arm makes contact but I would have to crank the adjustment screw on the idle stop bracket all the way (towards firewall side) to be in the range of adjustment which calls for a 5/16 gap with plunger pushed in. This would completely crush/compress tension spring on idle stop which makes no sense. Anyone else encounter this? Thanks
Idle Stop Solenoid Question
Originally posted by babywagI have never bothered with them.
Easy to remove and just use throttle stop screw on base of carb.
The manual tells how to adjust one if it even works properly after 35yrs.James
Previously 1987 GW
Ahaa!
I think that my solenoid should be the type that has the threads on the actual solenoid valve facing towards the front of GW which would allow for locating the valve closer to throttle stop. The style I have I believe to be incorrect for my carburetor or someone tried to replace oem original solenoid with what they were told is correct for an '88 GW -mysteries abound with this jeep. There is a lot to be said for all original unmolested vehicles . . .James
Previously 1987 GW
Photos of what yours looks like would help.
Drop the throttle to its engine throttle stop. The idle stop solenoid lifts it (the throttle) just a bit.
This is with the throttle held open on the fast idle cam as will be typical when working cold.
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
My other car is a fish
Thanks, will get a pic up but mine, set pretty much where yours is has no chance of making contact -weird!James
Previously 1987 GW
Realize that these solenoids can be there for at least two different purposes.
First, they could be an idle stop that pulls back at shutdown. This closes the throttle completely when the ignition is off, and prevents run-on (dieseling).
Or, it could be there to boost the idle speed under higher load. Typically this is when you turn the AC on, although I imagine there are other uses.
From the '89 TSM, it would seem this second point is the objective here. Look at page 14-175 figure 49. There is a very clear line drawing. The TSM will tell you a lot if you study it.Last edited by tgreese; 12-08-2022, 10:07 AM.Tim Reese
Yea. That's where having year specific info is needed.
In '85 its simply an idle stop solenoid.
There are versions that increase idle speed with the A/C on. Maybe that was done with the SJ's when they changed to the Sanden compressors?'85 Grand Wagoneer
360 727auto, NP229
body by beer (PO)
carries wood inside
no "wood" outside
