Originally posted by letank
ACCESSORIES ON WHEN KEY IS OFF
adjusting the switch on the column is a b##ch... the TSM gives you directions weather you have tilt or no tilt column because the switches are different... and install differently...
for years I did not have the accessory position nor had the cranking (I installed a bypass switch)... finally one day I moved the switch along the column a smidge, up then down... and all is good...
take a peek at the TSM on tom's site, scroll to your year model
https://oljeep.com/edge_parts_man.html
Leave a comment:
Originally posted by babywagTHIS^
Unless the problem existed previously to the replacement?
Leave a comment:
Leave a comment:
My 82 J10 has had an issue with the wipers, heater, etc remaining on when the key is off. I assumed it was the ignition switch (the electrical switch on the column under the dash) so I replaced it but no change. I can't think of anything else that would cause the accessories to be powered with the key off. Does anyone have any experience with this one?
Thanks
DanTags: None
Leave a comment:
