ACCESSORIES ON WHEN KEY IS OFF
  • ACCESSORIES ON WHEN KEY IS OFF
    My 82 J10 has had an issue with the wipers, heater, etc remaining on when the key is off. I assumed it was the ignition switch (the electrical switch on the column under the dash) so I replaced it but no change. I can't think of anything else that would cause the accessories to be powered with the key off. Does anyone have any experience with this one?
    Thanks
    Dan
    82 J10 SOA 6" SPRINGS D60-D70 W/DETROIT LOCKERS 38x15.5 TSL'S on 12" M/T CLASSICS 460 V-8 C-6 CUSTOM EFIS EFI AND HYDROBOOST
    That's weird. Are you sure the ignition is wired correctly?
      And switch under dash is adjusted correctly?
        THIS^
        Unless the problem existed previously to the replacement?
          Originally posted by babywag
          THIS^
          Yes I moved to switch manually and no matter where I put it same issue. This issue existed before I install the switch.
            adjusting the switch on the column is a b##ch... the TSM gives you directions weather you have tilt or no tilt column because the switches are different... and install differently...
            for years I did not have the accessory position nor had the cranking (I installed a bypass switch)... finally one day I moved the switch along the column a smidge, up then down... and all is good...
            take a peek at the TSM on tom's site, scroll to your year model
            https://oljeep.com/edge_parts_man.html
            Michel
            74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to the next get together without a rebuilt? Status: needs a new body.
            85 Gwag, 229 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
            See Ouray 2013, Engine bits and Fuel and brake lines, and Body work
              Thanks a lot. I will check it out.
