Some back ground:
AMC30 Stock heads and Edelbrock Performer Intake installed with Felpro valley pan.
I had a coolant leak at my front bolts on the Edelbrock intake and at the front corner of the intake where it meets the block and heads. I removed the intake, cleaned everything up, used a new felpro valley pan to install. I used a combination of Permetex "The right stuff", Aviation gasket and thread sealent (thread sealant for bolts). This fixed my leak at the head/manifold/block intersection but the bolts still leaking.
To my knowledge this only happens after driving for a bit, parking the jeep and then ill come back the next day and there is a pool of coolant at those front bolts in the manifold.
I drained coolant. Let dry out for a day, chased threads, installed bolts this time with Permatex #2, let dry for a day and and refilled, burped coolant system. This held up for a couple weeks and is now leaking again.
What can I do to stop this? I did a lot of research on how to install the intke manifold and what gaskets and gasket makers to use. Was very careful and precise. Just trying to stop this never ending leak.
Thanks!
Thanks!
