1971 Jeep. I'm installing new leaf springs. Stock height. As installed right now, the pin on the spring that aligns the spring to the axel is about an inch too far towards the front. Both sides of the leaf spring are installed.
The rear shackle is at an angle and not straight up and down as it is on the other side which I haven't removed yet. I think if I can get that corrected it should pull the spring back far enough to drop the pin of the spring into the hole on the axle. I'm just not sure of the best way to do that.
Should I push up on the spring until the shackle goes straight and then jack up the axel to match? Maybe I should have done the axle first?
I thought someone might have had the same issue and could save me trying ten different ways until I find the right one.
Thanks,
Thanks,
