CAM SUGGESTIONS
  • CAM SUGGESTIONS
    It's been awhile since I put together a 401 for a truck so I am going to build a 401 for my J-20 project that will start in the spring. Over the next few months i will put the engine together.
    Anyone suggest a hydraulic cam? It is an early 401 with 10.25:1 compression. Don't want anything lumpy just decent power. Recalling what I put in my CJ 401 I think it was around .485 lift and like 224 Degrees @ .050
    1977 CJ 7 360 T-18 IHC D300 FARM TRUCK NY
    1985 CJ 7 AMC 401, CLARK 285SV 5 SPEED, DANA 60, DANA 44, RUBICON 4.5 LIFT. 37 KRAWLERS
    1987 J-20 401 90% COMPLETED.
    1985 J-20 360 6 inch lift, 37's plow truck
    1986 J-20 360 stock well rusted plow truck
    1970 AMX CURRENT PROJECT
    I used a Comp Cams 268H in my 401. Once I had all the vacuum leaks fixed and the EFI tuned correctly, the idle had a really nice minor chop to it. in other words, if you were listening, you could tell it was not a stock cam but it did not sound crazy. It started well in SoCal cold mornings (40 degrees). I had enough vacuum to idle and run my brake booster.
    Power wise, it was better than stock but not a ton. A 401 cam is bigger than a 360 cam anyway. Looking back I wish it had a little more exhaust duration but for an off the shelf cam, it ran pretty good with an Edelbrock dual plane intake, long tube headers, and port matched stock heads.
    I have a video of the idle on my phone. If you PM me your cell number I will send it along.
      CAM
      I hear the Lunati Voodoo cam is great but unavailable
        I ran a Lunati RV-262 many years ago, not even sure if they market that grind anymore. It had great low-end torque, idled like stock. But since then cams have come a long way. Maybe the simple grinds are similar, but there are so many more options.
        I would call Lunati, Crane, Comp etc and talk to their tech people. Might get a good suggestion there, and maybe get a more thorough response taking into consideration your other engine specs.
        Cliff Danley
        1977 Cherokee S
          Here you go. try this. Like i said in the text, this is stone cold.
          https://drive.google.com/file/d/19Le...ew?usp=sharing
            Summit still makes the ol 8601
            part number SUM-8601
            Might be just right for a higher compression motor.
            Street/Strip
            Camshaft Manufacturers Description:
            Fair idle, excellent midrange power. Requires 9.5:1 and higher compression, 2,500+ stall, and gearing.
            Basic Operating RPM Range:
            2,200-5,500
            Intake Duration at 050 inch Lift:
            224
            Exhaust Duration at 050 inch Lift:
            234
            224 int./234 exh.
            Advertised Intake Duration:
            300
            Advertised Exhaust Duration: 304
            Advertised Duration: 300 int./304 exh.
            Intake Valve Lift with Factory Rocker Arm Ratio: 0.497 in.
            Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.520 in.
            Valve Lift with Factory Rocker Arm Ratio: 0.497 int./0.520 exh.
            Lobe Separation (degrees): 114
            Computer-Controlled Compatible: No
            Valve Springs Required: Yes
            '77 Cherokee S: 350 SBC, TH400, BW1339 Doug Nash PT, Performer intake, Carter AFB, & Mallory HEI. Needs: love
            '78 Cherokee S: 401 AMC, TH400, BW1339 w/ MM PT, Carter AFB, & BJs 4" Lift & Skyjacker Nitros. Needs: $ thrown at her
